跳转到主内容
Nexus 9 USB Daughterboard Replacement
你所需要的
  1. Nexus 9 USB Daughterboard Replacement, Rear Case: 步骤 1 中的图像 1,3 Nexus 9 USB Daughterboard Replacement, Rear Case: 步骤 1 中的图像 2,3 Nexus 9 USB Daughterboard Replacement, Rear Case: 步骤 1 中的图像 3,3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 USB Daughterboard Replacement, Vibrator Daughterboard: 步骤 2 中的图像 1,1
    • Disconnect the two ZIF connectors attached to the daughterboards.
    • Gently pull on the ribbon cable to remove it.
  3. Nexus 9 USB Daughterboard Replacement: 步骤 3 中的图像 1,2 Nexus 9 USB Daughterboard Replacement: 步骤 3 中的图像 2,2
    • Remove the two 3mm T5 Torx screws securing the metal USB port bracket.
    • Use your fingers or a pair of tweezers to remove the bracket.
  4. Nexus 9 USB Daughterboard Replacement: 步骤 4 中的图像 1,3 Nexus 9 USB Daughterboard Replacement: 步骤 4 中的图像 2,3 Nexus 9 USB Daughterboard Replacement: 步骤 4 中的图像 3,3
    • Unscrew the two 3mm T5 Torx screws securing the daughterboard to the device.
    • Use a pair of tweezers to disconnect the vibrator cable. It will lift straight up from the daughterboard connector.
    • Use your fingers to lift the daughterboard upward and out of the device.
  5. Nexus 9 USB Daughterboard Replacement: 步骤 5 中的图像 1,1
    • The daughterboard has an orange ribbon cable that is adhered to the device. Gently pull the ribbon up and remove the daughtboard.
  6. Nexus 9 USB Daughterboard Replacement, USB Daughterboard: 步骤 6 中的图像 1,1
    • Remove the single 3mm T5 Torx screw.
    • Use a spudger to disconnect the display ribbon cable ZIF connector.
    • Gently lift the USB daughterboard up from the device.
结论
3等其他人完成本指南。
Geoff Wacker
于09/30/13注册
88,185 声望
创作了89篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 34
总计 3,459
