跳转到主内容
Nexus 9 Rear Case Replacement
你所需要的
  1. Nexus 9 Rear Case Replacement, Rear Case: 步骤 1 中的图像 1,3 Nexus 9 Rear Case Replacement, Rear Case: 步骤 1 中的图像 2,3 Nexus 9 Rear Case Replacement, Rear Case: 步骤 1 中的图像 3,3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
结论
另外一个人完成了本指南。
Geoff Wacker
于09/30/13注册
89,956 声望
创作了89篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 1,291
