本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to replace the front-facing camera on your Nexus 9.
你所需要的
With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
Use a spudger to disconnect the front-facing camera ZIF connector.
Use a pair of tweezers to gently lift the front-facing camera up from the motherboard.
即将完成!
结论
另外一个人完成了本指南。
