跳转到主内容
Nexus 9 Front Facing Camera Replacement
你所需要的
  1. Nexus 9 Front Facing Camera Replacement, Rear Case: 步骤 1 中的图像 1,3 Nexus 9 Front Facing Camera Replacement, Rear Case: 步骤 1 中的图像 2,3 Nexus 9 Front Facing Camera Replacement, Rear Case: 步骤 1 中的图像 3,3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 Front Facing Camera Replacement, Front Facing Camera: 步骤 2 中的图像 1,1
    • Use a spudger to disconnect the front-facing camera ZIF connector.
    • Use a pair of tweezers to gently lift the front-facing camera up from the motherboard.
结论
另外一个人完成了本指南。
Geoff Wacker
于09/30/13注册
89,934 声望
创作了89篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 752
