本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to replace the antenna board on your Nexus 9.
你所需要的
With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
Carefully peel up the copper shielding with your fingers.
Before fully removing the copper shielding, make sure that the blue antenna cable is out of the way of the copper tab.
即将完成!
结论
