跳转到主内容
Nexus 9 Antenna Board Replacement
你所需要的
  1. Nexus 9 Antenna Board Replacement, Rear Case: 步骤 1 中的图像 1,3 Nexus 9 Antenna Board Replacement, Rear Case: 步骤 1 中的图像 2,3 Nexus 9 Antenna Board Replacement, Rear Case: 步骤 1 中的图像 3,3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 Antenna Board Replacement, Antenna Board: 步骤 2 中的图像 1,2 Nexus 9 Antenna Board Replacement, Antenna Board: 步骤 2 中的图像 2,2
    • This step is not necessary if you have already removed the battery.
    • Carefully peel up the copper shielding with your fingers.
    • Before fully removing the copper shielding, make sure that the blue antenna cable is out of the way of the copper tab.
  3. Nexus 9 Antenna Board Replacement: 步骤 3 中的图像 1,1
    • Unscrew the three 3 mm Torx T5 screws on the antenna board.
    • This step and the next show the battery removed, but it is not necessary to remove it if you are only replacing the antenna board.
  4. Nexus 9 Antenna Board Replacement: 步骤 4 中的图像 1,1
    • Use your fingers or a pair of tweezers to disconnect the blue antenna cable from the motherboard.
    • When reinstalling the antenna, be sure to clean it with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
    • The antenna board should now lift free of the motherboard.
结论
Geoff Wacker
于09/30/13注册
89,934 声望
创作了89篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,389
