跳转到主内容
Nexus 7 Rear Panel Replacement
你所需要的
  1. Nexus 7 Rear Panel Replacement, Rear Panel: 步骤 1 中的图像 1,1
    • In the following steps you will release the clips (highlighted in red) along the perimeter of the Nexus 7's rear panel.
    • Do not use excessive force while prying the clips. They can be easily broken.
  2. Nexus 7 Rear Panel Replacement: 步骤 2 中的图像 1,2 Nexus 7 Rear Panel Replacement: 步骤 2 中的图像 2,2
    • Gently insert a plastic opening tool near the top of the Nexus 7 between the rear panel and the front panel assembly.
    • Carefully run the plastic opening tool along the top edge to pry the rear panel away from the front panel assembly of the Nexus 7.
  3. Nexus 7 Rear Panel Replacement: 步骤 3 中的图像 1,3 Nexus 7 Rear Panel Replacement: 步骤 3 中的图像 2,3 Nexus 7 Rear Panel Replacement: 步骤 3 中的图像 3,3
    • Insert the plastic opening tool between the rear panel and the front panel assembly near the power button and pry up at several points along the right edge of the Nexus 7.
  4. Nexus 7 Rear Panel Replacement: 步骤 4 中的图像 1,3 Nexus 7 Rear Panel Replacement: 步骤 4 中的图像 2,3 Nexus 7 Rear Panel Replacement: 步骤 4 中的图像 3,3
    • Pry up the rear panel along the left edge using the method described in previous steps.
  5. Nexus 7 Rear Panel Replacement: 步骤 5 中的图像 1,2 Nexus 7 Rear Panel Replacement: 步骤 5 中的图像 2,2
    • Gently lift and remove the rear panel up off the front panel assembly.
结论
20等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 40
总计 52,321
