简介
This guide will show you how to replace the power and volume button ribbon cable.
工具
配件
没有特定配件。
Using the tip of a spudger, push first on one side then the other to "walk" the battery cable straight out of its socket on the motherboard.
Peel back the label covering the power and volume button ZIF connector.
Insert the flat end of a spudger between the power and volume button cable and the metal frame.
Carefully slide the spudger along the length of the ribbon cable, releasing the buttons.
T
4等其他人完成本指南。
7条评论
Hi All,
I've been to Orlando/FL this Sept/October and I bought 2 ASUS NEXUS 7 Tablets.
The first one was opened and used there, in Orlando. The second one, is a gift for my wife, and we had just unopened the box (yes, december/11/2012) and for our surprise the device simply do not turned on. I did a search on Internet, and I have opened the device. As we have two devices, I could compare and I noticed that it has a Missing "small flat cable", the one with the function of the buttons (power and volume).
I took a picture of both devices, if you tell me how, I can send you the pictures.
Where can I "buy" this small cable?
Thanks for your support.
The volume buttons on my Nexus 7 (2013) don't work. Is this procedure applicable to the 2013 version and do you think it will solve the problem?
Carl, Its the same fix as the Power& Volume Button Cable in our free guide u downloaded
