此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
揭开覆盖在主板底部的铜制 ESD 屏蔽层。
如果你只是更换 Micro USB 充电口,则无需像图中那样揭开铜制散热屏蔽层,拧下螺丝后,只需将扬声器组件移到一旁即可。如果需要更换扬声器,只需揭开底角以露出扬声器连接处即可。其余部分的散热屏蔽层请保持原样。
要重新组装设备,请按相反顺序执行这些说明。
146等其他人完成本指南。
32指南评论
This fix isn't too much of a pain if you can find the parts! The tape on the lower-left hand side was, oddly, a bit of a pain for me. Make sure you try to remove it from the left, and not from the right!
Got the cable and some recommended tools on Ebay for $30. Just did this on my old N7 and it works perfect now. Head up tho, the recommended tools didn't come with a small enough head for the two 2.3 mm black Phillips screws. Luckily i did have a super small one. Don't strip those or you SOL. Also the cable doesn't come with the headphone jack cover. it is held on with just tape so take that from the original cable.
Cable: http://www.ebay.com/itm/IO-PORT-CHARGER-...
Do a ebay search for "Nexus 7 I/O". Should pop up. Look for cheaper ones than the $60 ones.
Thank you so much for the clear guide. My Nexus 7 2012 is charging again! I ordered the part here: http://www.asusparts.eu/Asus-08301-00522...
Hans Iseger - 回复 分享
