跳转到主内容
Nexus 6 Headphone Jack Replacement
你所需要的
  1. Nexus 6 Headphone Jack Replacement, SIM Card: 步骤 1 中的图像 1,1
    • With a SIM card eject tool (a paperclip will work as well), push down on the hole at the top of the phone until the SIM card holder releases. This should not take much pressure.
    • Remove the SIM card and the SIM card holder.
  2. Nexus 6 Headphone Jack Replacement, Rear Case: 步骤 2 中的图像 1,2 Nexus 6 Headphone Jack Replacement, Rear Case: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    iOpener
    $14.99
    • Lay out a soft cloth on your workspace to prevent scratching the screen in this and future steps.
    • Pry open the back casing using the soft plastic opening pick.
    • Be careful of the Power & Volume Key ribbon on the left side just next to the volume key. The ribbon is exposed and could be damaged with the opening tool.
    • Carefully pull the back casing apart from the rest of the phone with your hands. Because the casing is glued to the rest of the phone, this step may require some force. Don't be alarmed if the casing flexes a bit.
    • You may need an iOpener to loosen up the adhesive. Check out the iOpener 指南 for info on how to use it.
  3. Nexus 6 Headphone Jack Replacement: 步骤 3 中的图像 1,1
    • Remove the twenty-two 2.3 mm T3 Torx screws with the T3 Torx Screwdriver.
  4. Nexus 6 Headphone Jack Replacement: 步骤 4 中的图像 1,3 Nexus 6 Headphone Jack Replacement: 步骤 4 中的图像 2,3 Nexus 6 Headphone Jack Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • With tweezers, remove the rubber protector on the lower part of the phone.
    • Disconnect the battery connector by gently prying it straight up with a spudger, on the side opposite the cable.
    • Completely separate the battery side from the motherboard side by gently pulling the sides apart with your hands.
  5. Nexus 6 Headphone Jack Replacement, Remove the headphone jack: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Using tweezers, remove the headphone jack by gently pulling it away from the rest of the phone.
结论
10等其他人完成本指南。
Marina Moore
于01/13/15注册
4,293 声望
创作了7篇指南
团队
Cal Poly, Team 70-3, Forte Winter 2015 Cal Poly, Team 70-3, Forte Winter 2015 的会员
CPSU-FORTE-W15S70G3
4 名成员
创作了30篇指南
1指南评论
thanks a lot for the guide!
I have a question and maybe someone can help me. I recently dropped by n6 in the toilet (yay) I'm not experiencing intermittent issues with the sound.
In short: sounds like youtube videos and in app sounds simply don't play unless headphones are plugged in. Also, when calling the mic and speaker do not respond, unless speaker phone is selected, or again unless i'm using headphones.
My actions: Taken off back and left in rice, factory reset, plugged in and out headphones many times, power cycled many times.
My diagnoses: the headphone jack believes it has headphones connected; even when they are not. Causing the no sound to play.
My question: would replacing the headphone jack be worthwhile for me?
A big thanks for any help or advice
Benjamin Westrup - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 45
过去 30 天: 120
总计 8,099
