简介
如果你的手机不能打开或者待机,更糟的是无法充电,那么你应该考虑更换电池了。本指南将向您展示如何从 Nexus 6 上移除并安装新的电池。
如果你的电池鼓包,采取适当的预防措施 。
你所需要的
按照本指南相反步骤来重新组装设备。
在完成本指南后,请校准你新安装的电池。
按照本指南相反步骤来重新组装设备。
在完成本指南后,请校准你新安装的电池。
107等其他人完成本指南。
由衷感谢以下译者:
87%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
43条评论
There's a *lot* of glued down parts. Don't force them apart. Use a hot-water bottle or similar to loosen the glue. Good luck!
Intriguing. I bought my nexus 6 thinking I would never be able to replace the battery, but this looks doable, albeit not without some risk of damaging the device.
David Betz - 回复
Hi David, Im in the same process and what I found is a lot of glue on the back, rather than that is fairly easy. :)
My battery side board has been broken! It did not hurt to work properly, but you guys MUST be careful of taking it apart!
Also T3 screws are so weak, Unscrew carefully and use a good T3 screw drivers otherwise they will be stripped!
