跳转到主内容
简介
Use this guide to remove the rear-facing camera in the Nexus 5X.
You’ll need replacement adhesive to reattach components when reassembling the device.
  1. Nexus 5X Rear-Facing Camera Replacement, SIM Card Tray: 步骤 1 中的图像 1,3 Nexus 5X Rear-Facing Camera Replacement, SIM Card Tray: 步骤 1 中的图像 2,3 Nexus 5X Rear-Facing Camera Replacement, SIM Card Tray: 步骤 1 中的图像 3,3
    • Insert a SIM card ejection tool into the hole on the SIM card tray, located on the left edge of the phone.
    • Press in to eject the SIM card tray.
    • Remove the SIM card tray.
  2. Nexus 5X Rear-Facing Camera Replacement, Rear Panel: 步骤 2 中的图像 1,3 Nexus 5X Rear-Facing Camera Replacement, Rear Panel: 步骤 2 中的图像 2,3 Nexus 5X Rear-Facing Camera Replacement, Rear Panel: 步骤 2 中的图像 3,3
    • Place an opening pick in the opening of the SIM card tray slot and twist it sideways to release the first plastic clip that holds the rear panel in its place.
    • Slide the opening pick around the top edge of the phone to release the plastic clips that secure the rear panel.
    A guitar pick is a good substitution for the plastic opening tool.
    Sam Sippe - 回复
    Here’s a photo of the location of the 18 tabs that hold the back cover in place
    Steve - 回复
    Twisting sideways didn’t do it for me, but sliding along the edge did. However, at first I didn’t realize that the pick was between the motherboard and midframe, rather than between midframe and back cover like it was supposed to. This led to breaking off a spring-loaded connector on the motherboard, connecting to an antenna (I guess) in the back cover. So far I haven’t noticed any reception issues, but I can’t say for sure.
    In essence: be careful to get the pick towards the back cover, and not “straight in” under the midframe.
    Hampus - 回复
  3. Nexus 5X Rear-Facing Camera Replacement: 步骤 3 中的图像 1,3 Nexus 5X Rear-Facing Camera Replacement: 步骤 3 中的图像 2,3 Nexus 5X Rear-Facing Camera Replacement: 步骤 3 中的图像 3,3
    • Continue to slide the opening pick around all sides of the phone to release all clips that secure the rear panel.
  4. Nexus 5X Rear-Facing Camera Replacement: 步骤 4 中的图像 1,2 Nexus 5X Rear-Facing Camera Replacement: 步骤 4 中的图像 2,2
    • Tilt the opening pick to lift the rear panel a little bit.
    • There are two more plastic clips next to the fingerprint sensor. Release them by gently pulling the rear panel.
    • Remove the rear panel.
  5. Nexus 5X Rear-Facing Camera Replacement, Midframe: 步骤 5 中的图像 1,1
    • Remove the ten 3.6 mm Phillips screws that secure the midframe.
    Some models use a Y1 screw head.
    Kyle Wright - 回复
  6. Nexus 5X Rear-Facing Camera Replacement: 步骤 6 中的图像 1,2 Nexus 5X Rear-Facing Camera Replacement: 步骤 6 中的图像 2,2
    • Insert an opening pick into the SIM card tray slot and twist the opening pick sideways to release the plastic clips.
    The photo seems to show that the person is opening from the top, which is the opposite of your advice. So, just want to be clear.
    Robert Konigsberg - 回复
    yes, open from bottom first... the pic above shows the finished product after reaching top of phone. I found it best to actually start close to the right of the usbC connector. Pushing inbetween the 2 tabs and up will release the shell.. then work clockwise.
    Chris Mayberry - 回复
    Chris, your advice to start to the right of the usbC connector was excellent, thank you!
    I found that my middle panel was already broken at the narrowest part just to the left of the 2-D scan code on the battery, perhaps from some ham-fisted previous repair. This seems of little consequence, there do not seem to be any electrical connections running through this part.
    Wiley Sanders - 回复
    After a long amount of prying, I discoved that, if used gently, a jimmy can really help get the plastic off
    Timothy Owens - 回复
    I could not remove the cover with the opening tool but had success with the opening picks (the triangle parts). Just slide them under the cover and gently bend and twist the pick to release the cover from the locks. By the way: it’s perfectly normal for the bottom cover part to come loose from the top cover part. It’s designed that way (they interlock).
    Marco Miltenburg - 回复
    Here’s a photo of the location of the 20 tabs that hold the middle assembly in place, and the pry angle needed.
    Steve - 回复
    This is the scariest part but it is the same process of taking a bike tire off the rim: lift up one part of the cover then put a wedge under the lifted section to hold it up then continue around the frame lifting it up and holding it up with the blue picks. You’ll find that after you life the bottom you can wriggle free the rest by hand.
    The 10 screws came out quickly using the IFIXIT.com magnetic screwdriver.
    mcguinness.david - 回复
  7. Nexus 5X Rear-Facing Camera Replacement: 步骤 7 中的图像 1,2 Nexus 5X Rear-Facing Camera Replacement: 步骤 7 中的图像 2,2
    • Continue sliding the opening pick around the upper part of the midframe to release the plastic clips.
  8. Nexus 5X Rear-Facing Camera Replacement: 步骤 8 中的图像 1,2 Nexus 5X Rear-Facing Camera Replacement: 步骤 8 中的图像 2,2
    • Use the plastic pick to pry open the plastic clips on the long edge of the midframe and on the bottom edge.
    • Make sure the clips on the long edge are released. The midframe is prone to break here if they are not disconnected properly.
  9. Nexus 5X Rear-Facing Camera Replacement: 步骤 9 中的图像 1,2 Nexus 5X Rear-Facing Camera Replacement: 步骤 9 中的图像 2,2
    • Make sure all the clips are free.
    • Carefully remove the midframe.
  10. Nexus 5X Rear-Facing Camera Replacement, Battery Disconnect: 步骤 10 中的图像 1,2 Nexus 5X Rear-Facing Camera Replacement, Battery Disconnect: 步骤 10 中的图像 2,2
    • Use the edge of a spudger to pry up and disconnect the battery flex cable located at the bottom right of the motherboard.
  11. Nexus 5X Rear-Facing Camera Replacement, Rear Facing Camera: 步骤 11 中的图像 1,2 Nexus 5X Rear-Facing Camera Replacement, Rear Facing Camera: 步骤 11 中的图像 2,2
    • Use the flat end of a spudger to pry up the rear facing camera's flex connector.
  12. Nexus 5X Rear-Facing Camera Replacement: 步骤 12 中的图像 1,1
    • Use an iOpener to loosen the adhesive beneath the rear facing camera. Place the iOpener across the top part of the phone for about 30 seconds.
  13. Nexus 5X Rear-Facing Camera Replacement: 步骤 13 中的图像 1,2 Nexus 5X Rear-Facing Camera Replacement: 步骤 13 中的图像 2,2
    • Apply the flat end of a spudger to the left side of the rear-facing camera and carefully lever it out of its recess.
  14. Nexus 5X Rear-Facing Camera Replacement: 步骤 14 中的图像 1,1
    • Use a pair of tweezers to remove the rear facing-camera.
结论
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
Repair didn’t go as planned? Check out our Nexus 5X Answers community for troubleshooting help.
10等其他人完成本指南。
Dominik Schnabelrauch
于2016年11月23日注册
146,761 声望
创作了601篇指南
团队
iFixit iFixit 的会员
Community
145 名成员
创作了16,156篇指南
7条评论
Hi! I just replaced the entire screen panel on my Nexus 5x because it stopped working (it flipped 180* the screen and the image it showed was mirrored -- completely impossible to use the phone). I read several reviews describing the same issue and fixing it by replacing the screen panel. Now I'm having issues with the camera. The front camera works, but the back one doesn't. I reopened the phone to check it was plugged in correctly to the motherboard, and it was. Is there a way to figure out if it's the actual camera that's not working or if it has something to do with the motherboard?
Thanks! -MJ
mariajrodriguezotoya - 回复
Hello,
I replaced the back camera, but unfortunately the autofocus of the new camera does not work. All pictures are blurred. When I open the camera-app a "click-noise" can be heard. I also installed 3rd-party app, which has the option to change the focus manually. But that did not work as well. I also did a secure boot, but that also did not solve the problem. Do you have an idea, what I can do?
Thanks in advance,
Klaus
Klaus M. - 回复
Hello,
just an update for my former question: I exchanged the camera-module again and now it is working. It seems, that the other "new" module was broken!
Cheers,
Klaus
Klaus M. -
I had a similar issue. After replacing the camera, the auto focus wouldn't work anymore. I did not test it with a manual focus app.
After some research i found out that this could have been caused by a faulty connection of the ribbon cable.
I reopened the phone, detached the ribbon cable and firmly pressed it on again. Had to repeat this twice, and after the second time the camera is doing auto focus again!
bert.wijnants -
Anyone knows where to buy the OEM Back Camera for the Nexus 5x? The connector is broken after screen replacement.
Maybe you guys can help me,
Remy B
Remy B - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 21
总计 8,419
