跳转到主内容
Nexus 5X Rear Panel Replacement
你所需要的
  1. Nexus 5X Rear Panel Replacement, SIM Card Tray: 步骤 1 中的图像 1,3 Nexus 5X Rear Panel Replacement, SIM Card Tray: 步骤 1 中的图像 2,3 Nexus 5X Rear Panel Replacement, SIM Card Tray: 步骤 1 中的图像 3,3
    • Insert a SIM card ejection tool into the hole on the SIM card tray, located on the left edge of the phone.
    • Press in to eject the SIM card tray.
    • Remove the SIM card tray.
  2. Nexus 5X Rear Panel Replacement, Rear Panel: 步骤 2 中的图像 1,3 Nexus 5X Rear Panel Replacement, Rear Panel: 步骤 2 中的图像 2,3 Nexus 5X Rear Panel Replacement, Rear Panel: 步骤 2 中的图像 3,3
    • Place an opening pick in the opening of the SIM card tray slot and twist it sideways to release the first plastic clip that holds the rear panel in its place.
    • Slide the opening pick around the top edge of the phone to release the plastic clips that secure the rear panel.
    A guitar pick is a good substitution for the plastic opening tool.
    Sam Sippe - 回复
    Here’s a photo of the location of the 18 tabs that hold the back cover in place
    Steve - 回复
    Twisting sideways didn’t do it for me, but sliding along the edge did. However, at first I didn’t realize that the pick was between the motherboard and midframe, rather than between midframe and back cover like it was supposed to. This led to breaking off a spring-loaded connector on the motherboard, connecting to an antenna (I guess) in the back cover. So far I haven’t noticed any reception issues, but I can’t say for sure.
    In essence: be careful to get the pick towards the back cover, and not “straight in” under the midframe.
    Hampus - 回复
  3. Nexus 5X Rear Panel Replacement: 步骤 3 中的图像 1,3 Nexus 5X Rear Panel Replacement: 步骤 3 中的图像 2,3 Nexus 5X Rear Panel Replacement: 步骤 3 中的图像 3,3
    • Continue to slide the opening pick around all sides of the phone to release all clips that secure the rear panel.
  4. Nexus 5X Rear Panel Replacement: 步骤 4 中的图像 1,2 Nexus 5X Rear Panel Replacement: 步骤 4 中的图像 2,2
    • Tilt the opening pick to lift the rear panel a little bit.
    • There are two more plastic clips next to the fingerprint sensor. Release them by gently pulling the rear panel.
    • Remove the rear panel.
结论
Repair didn’t go as planned? Check out our Nexus 5X Answers community for troubleshooting help.
26等其他人完成本指南。
Dominik Schnabelrauch
于11/23/16注册
201,012 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了16,560篇指南
一条评论
Bonjour,
Est-ce que vous arriveriez à m'indiquer l'espace disponible (en mm) entre le cache et la batterie svp?
Merci!
Lucas Marti - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 8,701
