跳转到主内容
加入维修社区 - 创建账户
你所需要的
视频概述
本篇指南是分解流程而非维修指南。 如果您要维修您的Nexus 5,应参考我们的维修指南
  1. Nexus 5 Teardown, Nexus 5 Teardown: 步骤 1 中的图像 1,3 Nexus 5 Teardown, Nexus 5 Teardown: 步骤 1 中的图像 2,3 Nexus 5 Teardown, Nexus 5 Teardown: 步骤 1 中的图像 3,3
    • The Nexus 5 is the first phone to ship with the latest version of Android's OS, KitKat. It may not be coated in chocolate, but it has plenty of tasty features:
    • 4.95" full HD 1920x1080 display at 445ppi
    • Quad-core, 2.26 GHz Snapdragon 800 processor and 450 MHz Adreno 330 GPU
    • 2 GB RAM
    • 8 MP/1080p rear camera with optical image stabilization, and 1.3 MP front-facing camera
    • 4G/LTE wireless support, 802.11 a/b/g/n/ac (2.4GHz and 5GHz) dual-band Wi-Fi, NFC, Bluetooth 4.0, and wireless charging
    • 16 GB or 32 GB built-in memory
    • Android 4.4 KitKat
  2. Nexus 5 Teardown: 步骤 2 中的图像 1,1
    • Sounds of joy emanate from the teardown factory as we find this Nexus is held together by…plastic clips!
    • These clips are plenty stubborn, but nothing like the headache that a glued panel would be.
    • Agent P.O.T. (plastic opening tool) is deployed to handle this noble mission.
  3. Nexus 5 Teardown: 步骤 3 中的图像 1,2 Nexus 5 Teardown: 步骤 3 中的图像 2,2
    • We may have cheered too soon—either someone spilled some chocolate syrup, or that's adhesive securing the bottom of the case.
    • Finding glue in your gadget is as much fun as finding chewed gum on your shoe.
    • Luckily this bit of foam adhesive is no match for a few swipes of a plastic opening pick. Our poor fixer souls have seen much worse recently.
    • With the adhesive out of the way, we get our first peek inside this delicious new device.
  4. Nexus 5 Teardown: 步骤 4 中的图像 1,3 Nexus 5 Teardown: 步骤 4 中的图像 2,3 Nexus 5 Teardown: 步骤 4 中的图像 3,3
    • Before taking another bite, we pause to chew over the back case:
    • We find conveniently labeled antennas for the Wi-Fi, MIMO, and GPS. It's not quite instructions, but hey, we'll take what we can get.
    • The NFC and wireless charging cables' spring contacts aren't so nicely identified, but are present and accounted for.
    • The vibrator is held in place with only a small amount of adhesive. That means an easy repair, should your phone lose its ability to shake it up.
    • How many licks screws does it take to get to the center of a Nexus 5?
    • No matter the number, our Pro Tech Screwdriver Set is up to the task.
    • Google gives us the Goldilocks of glue: It's just enough to hold the battery in place, but not too much—the battery can still be removed with minimal prying and virtually no bending.
    • Non-LG manufacturers, take note! We don't want none of your "that ain't possible" funny business when it comes to using glue in devices.
  5. Nexus 5 Teardown: 步骤 6 中的图像 1,3 Nexus 5 Teardown: 步骤 6 中的图像 2,3 Nexus 5 Teardown: 步骤 6 中的图像 3,3
    • LG's 3.8 V, 2300 mAh battery offers a slight jump in capacity over last year's Nexus 4.
    • Google boasts that this pack will keep you sugar-high for 17 hours of talk time, 300 hours of standby, or 7 hours of LTE web browsing.
    • We're pretty sure this warning icon indicates that it's unsafe to let pets smaller than this battery anywhere near it.
  6. Nexus 5 Teardown: 步骤 7 中的图像 1,3 Nexus 5 Teardown: 步骤 7 中的图像 2,3 Nexus 5 Teardown: 步骤 7 中的图像 3,3
    • Time to break us off a piece of this KitKat phone!
    • The speaker pops out with minimal fuss; it's only secured by few screws and no cables. This is the Nexus standard single speaker, despite the dual grilles.
    • No, this Nexus is not preparing for a BBQ—the second grille is for the microphone. Don't worry; we'll get there soon.
  7. Nexus 5 Teardown: 步骤 8 中的图像 1,3 Nexus 5 Teardown: 步骤 8 中的图像 2,3 Nexus 5 Teardown: 步骤 8 中的图像 3,3
    • We free the Oompa-Loompa-colored daughterboard, and she's got more goodies than the Easter Bunny:
    • Microphone
    • RGB Indicator LED
    • Micro-USB port
    • Speaker spring contacts
    • Antenna spring contacts
  8. Nexus 5 Teardown: 步骤 9 中的图像 1,3 Nexus 5 Teardown: 步骤 9 中的图像 2,3 Nexus 5 Teardown: 步骤 9 中的图像 3,3
    在这个步骤中使用的工具:
    Spudger
    $2.99
    • Less tasty, but more powerful than a Pixy Stick, our spudger makes motherboard removal easier than taking candy from a baby.
    • We quickly spudge away the wireless charging control and NFC board. LG built this little board into an EMI shield assembly that pops in right over the motherboard.
    • This shape reminds us a little of this helpful KitKat map
    • NFC is the tech behind Google Wallet—one of the Nexus devices' most loved features and one often blocked by carriers. Last month, the rumor mill speculated that the Nexus 5 would feature a Broadcom NFC controller that could eliminate carriers' ability to wallet-block customers.
    • Lo and behold: the Broadcom BCM20793M NFC controller.
    • Also on board: Texas Instruments BQ51013B Qi 1.1 Compliant Wireless Power Receiver
  9. Nexus 5 Teardown: 步骤 10 中的图像 1,1
    • That's some scrumptious silicon! Feast your eyes on these ICs:
    • Sandisk SDIN8DE4 16 GB NAND flash
    • Qualcomm WTR1605L LTE/HSPA+/CDMA2K/TDSCDMA/EDGE/GPS transceiver
    • Qualcomm PM8841 power management IC
    • Broadcom BCM4339 5G Wi-Fi combo chip with integrated power and low-noise amplifiers (the updated version of the BCM4335).
    • Avago RFI335
    • InvenSense MPU-6515 six-axis (gyro + accelerometer) MEMS MotionTracking device
    • Asahi Kasei AK8963 3-axis electronic compass
  10. Nexus 5 Teardown: 步骤 11 中的图像 1,1
    • SK Hynix H9CKNNNBPTMRLR-NTM 2 GB LPDDR3-1600 RAM
    • The Quad-core, 2.26 GHz Snapdragon 800 SoC is layered beneath the RAM
    • Qualcomm WCD9320 audio codec
    • Analogix ANX7808 SlimPort transmitter
    • Qualcomm PM8941 power management IC
    • Texas Instruments BQ24192 I2C controlled 4.5 A USB/adapter charger
    • Avago ACPM-7600 Multi Mode, Multi Band RF power amplifier
    • Qualcomm QFE1100 Envelope Tracking IC
  11. Nexus 5 Teardown: 步骤 12 中的图像 1,3 Nexus 5 Teardown: 步骤 12 中的图像 2,3 Nexus 5 Teardown: 步骤 12 中的图像 3,3
    • Out next is the 8MP rear-facing camera.
    • Google has taken some criticism for the less-than-impressive image capture in last year's candy-powered devices. This year they've added Optical Image Stabilization (OIS), but we've only heard tepid reviews so far.
    • The Nexus 5's OIS is powered by an InvenSense IDG-2020 dual axis gyroscope.
  12. Nexus 5 Teardown: 步骤 13 中的图像 1,3 Nexus 5 Teardown: 步骤 13 中的图像 2,3 Nexus 5 Teardown: 步骤 13 中的图像 3,3
    • We pop out the last of the bite-sized morsels in the Nexus 5:
    • Earpiece speaker
    • Headphone jack
    • 1.3 MP front-facing camera.
    • What a treat! These components were modular and only lightly adhered, seasoned just to our repair tastes.
  13. Nexus 5 Teardown: 步骤 14 中的图像 1,2 Nexus 5 Teardown: 步骤 14 中的图像 2,2
    • Unfortunately, our hopes come crashing down like a blood sugar crash after a candy binge: the front panel is one fused flustercluck.
    • While we saw this in the Nexus 4, we had hoped the LG/Google team could learn the error of their ways.
    • Alas, the front frame, LCD, and glass are doomed to a single shared death sometime down the road to Candy Land.
    • Imagine if one cavity meant losing all your teeth... Talk about a hard pill to swallow.
    • Tucked in at the base of the display, a Synaptics S3350B IC provides touchscreen control.
  14. Nexus 5 Teardown: 步骤 15 中的图像 1,2 Nexus 5 Teardown: 步骤 15 中的图像 2,2
    • Nexus 5 Repairability Score: 8 out of 10 (10 is easiest to repair).
    • Very modular design allows independent replacement of several wear-prone components—like the headphone jack and speakers.
    • Only very mild adhesive holds the battery in place, making it fairly easy to safely remove and replace.
    • Standardized screws (ten identical #00 Phillips) simplify repairs and reassembly.
    • The back cover is held in place with plastic clips. Sturdy and rather difficult to remove, but easier than glue.
    • The glass and LCD are fused to the display frame. Fixing broken glass will be either expensive or very difficult.
63指南评论
It looks like the old assembled desk top PC, with lot of connectors and ICs, each dedicated functional IC's, with lot many juggler connectors,
dvg234 - 回复 分享
Step 6
Why add any thickness of a label over that battery when the battery would never be seen after manufacturing sealed it in? That would be like putting a label over every IC in the phone.
ldunbarl - 回复 分享
does it have ir blaster? i want that nexus 5 comes with ir blaster :( i think it doesnt have ir blaster :(
Licenciado Nexus - 回复 分享
There is no IR blaster, but ridiculously, Kitkat has native support for it. Sometimes I really don't understand Google; Nexus line is supposed to be a dev phone, so why they decided to cut down the IR blaster, when there is software for it, is a big mystery...
Alexander Tatevyan - 分享
The phone comes with a back hoop with a pin to release the SIM card. I stupidly stuck this in the tiny hole at the top of the Nexus 5 that I believe is actually a secondary microphone. I was wondering, using your dismantled phone, if you stick the black pin into the hole can you tell whether it damages the microphone?
Matt Williams - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 65
过去 30 天: 371
总计 907,002
