跳转到主内容
加入维修社区 - 创建账户
Nexus 5 SIM Card Replacement
你所需要的
  1. Nexus 5 SIM Card Replacement, SIM Card: 步骤 1 中的图像 1,2 Nexus 5 SIM Card Replacement, SIM Card: 步骤 1 中的图像 2,2
    • Power off the device by holding the power button until the "Power Off" popup appears. Tap the popup and wait for the device to turn off.
    • Insert a SIM card eject tool or a paper clip into the hole next to the SIM card slot, which is located just under the power button. Do not force the paper clip if it is too thick; instead use the head of a sewing needle.
    • Push the tool into the hole until you see the card pop out.
  2. Nexus 5 SIM Card Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    • Gently remove the SIM card with your fingers, or a pair of tweezers if the SIM holder does not fully eject.
    • Make sure the chip is facing the rear of the phone when reinserting the SIM card.
结论
2等其他人完成本指南。
Kyle Libby
于04/07/14注册
1,006 声望
创作了7篇指南
团队
Cal Poly, Team 7-23, Regan Spring 2014 Cal Poly, Team 7-23, Regan Spring 2014 的会员
CPSU-REGAN-S14S7G23
4 名成员
创作了19篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 22
总计 4,339
