跳转到主内容
Nexus 5 Antenna Cable Replacement
你所需要的
  1. Nexus 5 Antenna Cable Replacement, Remove the Battery Door: 步骤 1 中的图像 1,1
    • The battery door of the Nexus 5 is held together with plastic clips.
    • Use the plastic spudger to separate the battery door.
  2. Nexus 5 Antenna Cable Replacement, Unscrew the Midframe and Speaker Assemby: 步骤 2 中的图像 1,3 Nexus 5 Antenna Cable Replacement, Unscrew the Midframe and Speaker Assemby: 步骤 2 中的图像 2,3 Nexus 5 Antenna Cable Replacement, Unscrew the Midframe and Speaker Assemby: 步骤 2 中的图像 3,3
    • Using your #00 Philips Screwdriver, remove the six screws holding the midframe in place.
    • Remove the four screws at the bottom of the device holding the speaker assembly in place.
    • The screw on the far right may be covered in adhesive. Use your plastic spudger to remove the adhesive covering the screw.
  3. Nexus 5 Antenna Cable Replacement, Remove the Midframe and Speaker Assembly: 步骤 3 中的图像 1,2 Nexus 5 Antenna Cable Replacement, Remove the Midframe and Speaker Assembly: 步骤 3 中的图像 2,2
    • Remove the midframe and speaker assembly.
  4. Nexus 5 Antenna Cable Replacement, Remove and Replace the Antenna Cables: 步骤 4 中的图像 1,3 Nexus 5 Antenna Cable Replacement, Remove and Replace the Antenna Cables: 步骤 4 中的图像 2,3 Nexus 5 Antenna Cable Replacement, Remove and Replace the Antenna Cables: 步骤 4 中的图像 3,3
    • The antenna cables are located on the right and left side of the battery (one is gray, the other is black).
    • Using your plastic spudger, disconnect both ends of the antenna cables.
    • Connect your new antenna cables.
    • Make sure the antenna cables are securely connected.
  5. Nexus 5 Antenna Cable Replacement, Reassemble the Device: 步骤 5 中的图像 1,2 Nexus 5 Antenna Cable Replacement, Reassemble the Device: 步骤 5 中的图像 2,2
    • Screw the midframe and speaker assembly back into place.
    • Push the outer edges of the battery door down until you hear the plastic clips "click."
    • Hold the power button until you feel the phone vibrate and/or see the Google logo displayed.
终点
另外一个人完成了本指南。
Tyler Caldwell
于12/07/17注册
184 声望
撰写一个指南
团队
IUPUI, Team S1-G1, Baechle Fall 2017 IUPUI, Team S1-G1, Baechle Fall 2017 的会员
IUPUI-BAECHLE-F17S1G1
2 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 20
总计 3,028
