本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide will detail how to remove and install the phone's speakers, located at the bottom of the Nexus 4.
你所需要的
在这个步骤中使用的工具:SIM Card Eject Tool$2.99
Power off the phone, by long-pressing the power button and touching Power off.
Remove the SIM tray using the SIM Card Eject Tool.
在这个步骤中使用的工具:T5 Torx Screwdriver$5.49
Remove the two screws from the bottom of the phone with a T5 Torx Screwdriver.
Remove the two 1.8 mm Phillips screws holding down the battery connector.
Using a plastic opening tool, disconnect the battery cable from its socket on the motherboard.
在这个步骤中使用的工具:Plastic Cards$2.99
Remove the blue tape that secures the white antenna cable to the battery.
Using a spudger, carefully disconnect the white antenna cable.
Carefully pry the battery out with a Plastic Opening Tool, starting at the top left-hand corner and working down towards the bottom right-hand corner.
Remove the two 4.8 mm screws that hold the speaker enclosure together using the Phillips 00 screwdriver.
10等其他人完成本指南。
