跳转到主内容
Nexus 4 Power and Volume Button Replacement
你所需要的
  1. Nexus 4 Power and Volume Button Replacement, Back Cover: 步骤 1 中的图像 1,2 Nexus 4 Power and Volume Button Replacement, Back Cover: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    SIM Card Eject Tool
    $2.99
    • Power off the phone, by long-pressing the power button and touching Power off.
    • Remove the SIM tray using the SIM Card Eject Tool.
    • This step is required in order to remove the back case.
  2. Nexus 4 Power and Volume Button Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    T5 Torx Screwdriver
    $5.49
  3. Nexus 4 Power and Volume Button Replacement: 步骤 3 中的图像 1,3 Nexus 4 Power and Volume Button Replacement: 步骤 3 中的图像 2,3 Nexus 4 Power and Volume Button Replacement: 步骤 3 中的图像 3,3
    • Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
    • The opening process may take a few minutes. The plastic will make a light snapping noise as the back cover separates from the rest of the phone.
  4. Nexus 4 Power and Volume Button Replacement, Power and Volume Button: 步骤 4 中的图像 1,2 Nexus 4 Power and Volume Button Replacement, Power and Volume Button: 步骤 4 中的图像 2,2
    • Holding the back case, gently push the power button in towards the center of the phone using a spudger.
  5. Nexus 4 Power and Volume Button Replacement: 步骤 5 中的图像 1,3 Nexus 4 Power and Volume Button Replacement: 步骤 5 中的图像 2,3 Nexus 4 Power and Volume Button Replacement: 步骤 5 中的图像 3,3
    • To remove the volume button, push the button in towards the center of the phone using a spudger.
结论
16等其他人完成本指南。
Kaitlyn Jones
于01/27/13注册
4,964 声望
创作了8篇指南
团队
Cal Poly, Team 3-32, Amido Winter 2013 Cal Poly, Team 3-32, Amido Winter 2013 的会员
CPSU-AMIDO-W13S3G32
4 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 15
总计 30,000
