跳转到主内容
加入维修社区 - 创建账户
Nexus 10 USB Port Replacement
你所需要的
  1. Nexus 10 USB Port Replacement, Battery: 步骤 1 中的图像 1,3 Nexus 10 USB Port Replacement, Battery: 步骤 1 中的图像 2,3 Nexus 10 USB Port Replacement, Battery: 步骤 1 中的图像 3,3
    • Using a plastic opening tool, remove the thin plastic cover from back of the tablet by prying up from its small tab.
    询问修复机器人
    添加评论
  2. Nexus 10 USB Port Replacement: 步骤 2 中的图像 1,1
    • Remove the five 2mm screws on the back of the device using a PH00 screwdriver.
    询问修复机器人
    添加评论
  3. Nexus 10 USB Port Replacement: 步骤 3 中的图像 1,3 Nexus 10 USB Port Replacement: 步骤 3 中的图像 2,3 Nexus 10 USB Port Replacement: 步骤 3 中的图像 3,3
    • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
    • Pull the the plastic backing off the display assembly using your hands.
    • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
    添加评论
  4. Nexus 10 USB Port Replacement: 步骤 4 中的图像 1,3 Nexus 10 USB Port Replacement: 步骤 4 中的图像 2,3 Nexus 10 USB Port Replacement: 步骤 4 中的图像 3,3
    • Detach the three connector ribbons passing over the battery using the plastic opening tool.
    添加评论
  5. Nexus 10 USB Port Replacement: 步骤 5 中的图像 1,1
    • Remove the twelve 2mm screws around the perimeter of the battery with a PH00 screwdriver.
    询问修复机器人
    添加评论
  6. Nexus 10 USB Port Replacement: 步骤 6 中的图像 1,2 Nexus 10 USB Port Replacement: 步骤 6 中的图像 2,2
    • Disconnect the battery by lifting it upward and pulling it away from the connector.
    添加评论
  7. Nexus 10 USB Port Replacement, Headphone Jack: 步骤 7 中的图像 1,1
    • Remove one screw on the logic board with a PH00 screwdriver.
    询问修复机器人
    添加评论
  8. Nexus 10 USB Port Replacement: 步骤 8 中的图像 1,3 Nexus 10 USB Port Replacement: 步骤 8 中的图像 2,3 Nexus 10 USB Port Replacement: 步骤 8 中的图像 3,3
    • Disconnect right speaker connector ribbon from logic board.
    • Lift the speaker out by pulling up on its corner.
    询问修复机器人
    添加评论
  9. Nexus 10 USB Port Replacement: 步骤 9 中的图像 1,3 Nexus 10 USB Port Replacement: 步骤 9 中的图像 2,3 Nexus 10 USB Port Replacement: 步骤 9 中的图像 3,3
    • Disconnect connectors around the perimeter of the motherboard.
    询问修复机器人
    添加评论
  10. Nexus 10 USB Port Replacement: 步骤 10 中的图像 1,2 Nexus 10 USB Port Replacement: 步骤 10 中的图像 2,2
    • Remove motherboard by gently pulling upward under its corner.
    询问修复机器人
    添加评论
  11. Nexus 10 USB Port Replacement: 步骤 11 中的图像 1,1
    • Remove the three 2mm screws along the right side of the device using a PH00 screwdriver.
    询问修复机器人
    添加评论
  12. Nexus 10 USB Port Replacement: 步骤 12 中的图像 1,2 Nexus 10 USB Port Replacement: 步骤 12 中的图像 2,2
    • Unseat the small vibrator motor by gently applying upward pressure with a spudger.
    添加评论
  13. Nexus 10 USB Port Replacement: 步骤 13 中的图像 1,2 Nexus 10 USB Port Replacement: 步骤 13 中的图像 2,2
    • Lift the assembly by gently applying upward pressure with the spudger on the assembly.
    询问修复机器人
    添加评论
  14. Nexus 10 USB Port Replacement: 步骤 14 中的图像 1,2 Nexus 10 USB Port Replacement: 步骤 14 中的图像 2,2
    • Gently pull battery-audio jack-USB assembly upward, detaching it from its adhesive.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
7等其他人完成本指南。
团队
Cal Poly, Team 34-18, Maness Spring 2016 Cal Poly, Team 34-18, Maness Spring 2016 的会员
CPSU-MANESS-S16S34G18
4 名成员
创作了5篇指南
1指南评论
Perfect guide, I managed to fix my Nexus 10 broken usb port.
It may be worth to mention after step 14 you need to gently remove the plastic connectors cover and place it on the replacement part.
Mauri - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 40
总计 6,261
