跳转到主内容
Nexus 10 Front Facing Camera Replacement
你所需要的
  1. Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: 步骤 1 中的图像 1,3 Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: 步骤 1 中的图像 2,3 Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: 步骤 1 中的图像 3,3
    • Remove the plastic cover located on the back of the device by prying off one side of the cover with a plastic opening device and peeling it back.
  2. Nexus 10 Front Facing Camera Replacement: 步骤 2 中的图像 1,3 Nexus 10 Front Facing Camera Replacement: 步骤 2 中的图像 2,3 Nexus 10 Front Facing Camera Replacement: 步骤 2 中的图像 3,3
    • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
    • Pull the the plastic backing off the display assembly using your hands.
    • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
  3. Nexus 10 Front Facing Camera Replacement: 步骤 3 中的图像 1,3 Nexus 10 Front Facing Camera Replacement: 步骤 3 中的图像 2,3 Nexus 10 Front Facing Camera Replacement: 步骤 3 中的图像 3,3
    • Lift latch on front-facing camera connector.
    • Pull the connector toward the top of the device and remove the front-facing camera.
结论
Benjamin Troller
于04/11/16注册
2,181 声望
创作了5篇指南
团队
Cal Poly, Team 34-18, Maness Spring 2016 Cal Poly, Team 34-18, Maness Spring 2016 的会员
CPSU-MANESS-S16S34G18
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 592
