跳转到主内容
Nexus 10 Display Replacement
你所需要的
  1. Nexus 10 Display Replacement, Battery: 步骤 1 中的图像 1,3 Nexus 10 Display Replacement, Battery: 步骤 1 中的图像 2,3 Nexus 10 Display Replacement, Battery: 步骤 1 中的图像 3,3
    • Using a plastic opening tool, remove the thin plastic cover from back of the tablet by prying up from its small tab.
  2. Nexus 10 Display Replacement: 步骤 2 中的图像 1,1
    • Remove the five 2mm screws on the back of the device using a PH00 screwdriver.
  3. Nexus 10 Display Replacement: 步骤 3 中的图像 1,3 Nexus 10 Display Replacement: 步骤 3 中的图像 2,3 Nexus 10 Display Replacement: 步骤 3 中的图像 3,3
    • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
    • Pull the the plastic backing off the display assembly using your hands.
    • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
  4. Nexus 10 Display Replacement: 步骤 4 中的图像 1,3 Nexus 10 Display Replacement: 步骤 4 中的图像 2,3 Nexus 10 Display Replacement: 步骤 4 中的图像 3,3
    • Detach the three connector ribbons passing over the battery using the plastic opening tool.
  5. Nexus 10 Display Replacement: 步骤 5 中的图像 1,1
    • Remove the twelve 2mm screws around the perimeter of the battery with a PH00 screwdriver.
  6. Nexus 10 Display Replacement: 步骤 6 中的图像 1,2 Nexus 10 Display Replacement: 步骤 6 中的图像 2,2
    • Disconnect the battery by lifting it upward and pulling it away from the connector.
  7. Nexus 10 Display Replacement, Headphone Jack: 步骤 7 中的图像 1,1
    • Remove one screw on the logic board with a PH00 screwdriver.
  8. Nexus 10 Display Replacement: 步骤 8 中的图像 1,3 Nexus 10 Display Replacement: 步骤 8 中的图像 2,3 Nexus 10 Display Replacement: 步骤 8 中的图像 3,3
    • Disconnect right speaker connector ribbon from logic board.
    • Lift the speaker out by pulling up on its corner.
  9. Nexus 10 Display Replacement: 步骤 9 中的图像 1,3 Nexus 10 Display Replacement: 步骤 9 中的图像 2,3 Nexus 10 Display Replacement: 步骤 9 中的图像 3,3
    • Disconnect connectors around the perimeter of the motherboard.
  10. Nexus 10 Display Replacement: 步骤 10 中的图像 1,2 Nexus 10 Display Replacement: 步骤 10 中的图像 2,2
    • Remove motherboard by gently pulling upward under its corner.
  11. Nexus 10 Display Replacement: 步骤 11 中的图像 1,1
    • Remove the three 2mm screws along the right side of the device using a PH00 screwdriver.
  12. Nexus 10 Display Replacement: 步骤 12 中的图像 1,2 Nexus 10 Display Replacement: 步骤 12 中的图像 2,2
    • Unseat the small vibrator motor by gently applying upward pressure with a spudger.
  13. Nexus 10 Display Replacement: 步骤 13 中的图像 1,2 Nexus 10 Display Replacement: 步骤 13 中的图像 2,2
    • Lift the assembly by gently applying upward pressure with the spudger on the assembly.
  14. Nexus 10 Display Replacement: 步骤 14 中的图像 1,2 Nexus 10 Display Replacement: 步骤 14 中的图像 2,2
    • Gently pull battery-audio jack-USB assembly upward, detaching it from its adhesive.
  15. Nexus 10 Display Replacement, Display: 步骤 15 中的图像 1,2 Nexus 10 Display Replacement, Display: 步骤 15 中的图像 2,2
    • Detach LCD connector ribbon by pressing upward on connector latch using a plastic opening tool.
  16. Nexus 10 Display Replacement: 步骤 16 中的图像 1,2 Nexus 10 Display Replacement: 步骤 16 中的图像 2,2
    • Unscrew the two 2mm Phillips #00 screws holding the ribbon in place.
    • Remove the board by tilting it forward and pulling outward.
  17. Nexus 10 Display Replacement: 步骤 17 中的图像 1,1
    • Remove second speaker by gently tilting and pulling upward.
  18. Nexus 10 Display Replacement: 步骤 18 中的图像 1,3 Nexus 10 Display Replacement: 步骤 18 中的图像 2,3 Nexus 10 Display Replacement: 步骤 18 中的图像 3,3
    • Unscrew the two 2mm screws securing the micro HDMI connector with a #PH00 screwdriver.
    • Remove the connector by liberally applying upward pressure.
  19. Nexus 10 Display Replacement: 步骤 19 中的图像 1,3 Nexus 10 Display Replacement: 步骤 19 中的图像 2,3 Nexus 10 Display Replacement: 步骤 19 中的图像 3,3
    • Unscrew the 2mm Phillips #00 screw that holds the flash enclosure.
    • Remove the flash assembly with a plastic opening tool by lifting the assembly upward.
结论
6等其他人完成本指南。
Benjamin Troller
于04/11/16注册
2,218 声望
创作了5篇指南
团队
Cal Poly, Team 34-18, Maness Spring 2016 Cal Poly, Team 34-18, Maness Spring 2016 的会员
CPSU-MANESS-S16S34G18
4 名成员
创作了5篇指南
4指南评论
I’m waiting for the instructions regarding how to remove the old screen and insert the new - it seems to be missing
John Walker - 回复
It seems you just have to buy a replacement for that whole front housing, including the screen assembly
Oliver Nichol -
Still waiting to see how the screen is remove
Frank - 回复
he cambiado la bateria y he partido el presor negro del conector de LCD y no me me funciona, se puede comprar esa pieza negra?
Diego Mera - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 58
总计 8,643
