跳转到主内容
Nextplay NP109CR Speakers Replacement
你所需要的
  1. Nextplay NP109CR Speakers Replacement, Speakers: 步骤 1 中的图像 1,1
    • Turn the device over so it is upside-down.
  2. Nextplay NP109CR Speakers Replacement: 步骤 2 中的图像 1,1
    • Unscrew the 4 screws closest to the screen.
  3. Nextplay NP109CR Speakers Replacement: 步骤 3 中的图像 1,1
    • Flip over the device so it is right side up.
  4. Nextplay NP109CR Speakers Replacement: 步骤 4 中的图像 1,1
    • Unscrew the 2 screws on the top of the device, next to the docking plug.
  5. Nextplay NP109CR Speakers Replacement: 步骤 5 中的图像 1,1
    • Take off top piece by using slight force and pulling off.
  6. Nextplay NP109CR Speakers Replacement: 步骤 6 中的图像 1,1
    • Unscrew the button board with smaller screwdriver.
  7. Nextplay NP109CR Speakers Replacement: 步骤 7 中的图像 1,1
    • Lift off the button board.
  8. Nextplay NP109CR Speakers Replacement: 步骤 8 中的图像 1,1
    • Unscrew all visible of the screws on the black logic board cover with the larger screwdriver.
  9. Nextplay NP109CR Speakers Replacement: 步骤 9 中的图像 1,1
    • Lift the screen vertically straight up.
    • As you do this the logic board should move off with it.
  10. Nextplay NP109CR Speakers Replacement: 步骤 10 中的图像 1,1
    • Flip the screen and the logic board over to the right side.
  11. Nextplay NP109CR Speakers Replacement: 步骤 11 中的图像 1,1
    • Pull out the white plug that goes from the speakers to the logic board.
    • Then plug back in making sure it is completely connected.
结论
Michelle Read
于09/26/12注册
1 声望
撰写一个指南
团队
Cal Poly, Team 7-50, Forte Fall 2012 Cal Poly, Team 7-50, Forte Fall 2012 的会员
CPSU-FORTE-F12S7G50
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 390
