1. Turn the device over so it is upside-down.
    • Turn the device over so it is upside-down.
  2. Unscrew the 4 screws closest to the screen.
    • Unscrew the 4 screws closest to the screen.
  3. Flip over the device so it is right side up.
    • Flip over the device so it is right side up.
  4. Unscrew the 2 screws on the top of the device, next to the docking plug.
    • Unscrew the 2 screws on the top of the device, next to the docking plug.
  5. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  6. Take off top piece by using slight force and pulling off.
    • Take off top piece by using slight force and pulling off.
  7. Unscrew the button board with smaller screwdriver.
    • Unscrew the button board with smaller screwdriver.
  8. Lift off the button board.
    • Lift off the button board.
  9. Unscrew all visible of the screws on the black logic board cover with the larger screwdriver.
    • Unscrew all visible of the screws on the black logic board cover with the larger screwdriver.
  10. Lift the screen vertically straight up.
    • Lift the screen vertically straight up.
      • As you do this the logic board should move off with it.
  11. Flip the screen and the logic board over to the right side.
    • Flip the screen and the logic board over to the right side.
  12. Pull out the white plug that goes from the speakers to the logic board.
    • Pull out the white plug that goes from the speakers to the logic board.
    • Then plug back in making sure it is completely connected.
结论
Michelle Read
于2012年09月26日注册
1 信誉积分
撰写一个指南
团队
Cal Poly, Team 7-50, Forte Fall 2012 Cal Poly, Team 7-50, Forte Fall 2012 的会员
CPSU-FORTE-F12S7G50
5 名成员
创作了8篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 302
