跳转到主内容
Nextbook NXA8QC116B Battery Replacement
你所需要的
  1. Nextbook NXA8QC116B Battery Replacement, Battery: 步骤 1 中的图像 1,3 Nextbook NXA8QC116B Battery Replacement, Battery: 步骤 1 中的图像 2,3 Nextbook NXA8QC116B Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • If you see any leakage coming from the tablet do not open the back cover!
    • Ensure you do not pry around the buttons. This could result in damage and render them inoperable.
    • •With the tip of the thin metal spudger in place, use a prying motion to work the spudger down the side to the corner of the device.
  2. Nextbook NXA8QC116B Battery Replacement: 步骤 2 中的图像 1,2 Nextbook NXA8QC116B Battery Replacement: 步骤 2 中的图像 2,2
    • Continue working the spudger downward and pry with the spudger until the bottom left-hand corner of the tablet is reached.
  3. Nextbook NXA8QC116B Battery Replacement: 步骤 3 中的图像 1,3 Nextbook NXA8QC116B Battery Replacement: 步骤 3 中的图像 2,3 Nextbook NXA8QC116B Battery Replacement: 步骤 3 中的图像 3,3
    • Along the bottom of the tablet, keep using a working and prying motion with the spudger to loosen the cover.
  4. Nextbook NXA8QC116B Battery Replacement: 步骤 4 中的图像 1,3 Nextbook NXA8QC116B Battery Replacement: 步骤 4 中的图像 2,3 Nextbook NXA8QC116B Battery Replacement: 步骤 4 中的图像 3,3
    • Continue prying motion until the bottom right-hand corner of the tablet is reached.
  5. Nextbook NXA8QC116B Battery Replacement: 步骤 5 中的图像 1,2 Nextbook NXA8QC116B Battery Replacement: 步骤 5 中的图像 2,2
    • Work the spudger to the upper left-hand corner of the tablet.
  6. Nextbook NXA8QC116B Battery Replacement: 步骤 6 中的图像 1,3 Nextbook NXA8QC116B Battery Replacement: 步骤 6 中的图像 2,3 Nextbook NXA8QC116B Battery Replacement: 步骤 6 中的图像 3,3
    • Be careful once you get to the top of the tablet with the spudger so as not to damage the headphone jack and other ports.
    • When prying along the top of the tablet, try to keep the spudger between 70 to 85 degrees (almost perpendicular) to the tablet screen.
    • Continue working the spudger around the tablet until the cover of the device comes off
  7. Nextbook NXA8QC116B Battery Replacement: 步骤 7 中的图像 1,2 Nextbook NXA8QC116B Battery Replacement: 步骤 7 中的图像 2,2
    • Separate from the cover from the tablet.
  8. Nextbook NXA8QC116B Battery Replacement: 步骤 8 中的图像 1,3 Nextbook NXA8QC116B Battery Replacement: 步骤 8 中的图像 2,3 Nextbook NXA8QC116B Battery Replacement: 步骤 8 中的图像 3,3
    • Locate and carefully remove the yellow cellophane tape from the red and black speaker wires that connect the speaker to the edge of the motherboard.
  9. Nextbook NXA8QC116B Battery Replacement: 步骤 9 中的图像 1,2 Nextbook NXA8QC116B Battery Replacement: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Locate and carefully remove the yellow cellophane tape with tweezers from the battery connector and black and red speaker wires on the edge of the motherboard.
  10. Nextbook NXA8QC116B Battery Replacement: 步骤 10 中的图像 1,3 Nextbook NXA8QC116B Battery Replacement: 步骤 10 中的图像 2,3 Nextbook NXA8QC116B Battery Replacement: 步骤 10 中的图像 3,3
    • Using small pliers, carefully disconnect the male battery connector from the motherboard.
    • If you are only replacing the front camera, skip to step 17 in the camera replacement guide and continue.
  11. Nextbook NXA8QC116B Battery Replacement: 步骤 11 中的图像 1,1
    • If the battery is leaking or bulging, stop and get away from it!
    • Carefully remove the gray square pad glued to both the white ribbon cable and the battery by pulling slowly.
  12. Nextbook NXA8QC116B Battery Replacement: 步骤 12 中的图像 1,1
    • Locate the white ribbon cable Zero Insertion Force (ZIF) connector between the battery and the motherboard, and peel the yellow cellophane tape off the connector.
  13. Nextbook NXA8QC116B Battery Replacement: 步骤 13 中的图像 1,2 Nextbook NXA8QC116B Battery Replacement: 步骤 13 中的图像 2,2
    • Flip up the gray retainer clip on the white ribbon cable ZIF connector on the motherboard with your fingernail. If you do not have fingernails long enough, carefully use a black plastic spudger.
  14. Nextbook NXA8QC116B Battery Replacement: 步骤 14 中的图像 1,3 Nextbook NXA8QC116B Battery Replacement: 步骤 14 中的图像 2,3 Nextbook NXA8QC116B Battery Replacement: 步骤 14 中的图像 3,3
    • Remove the white ribbon cable and carefully peel it off the battery.
  15. Nextbook NXA8QC116B Battery Replacement: 步骤 15 中的图像 1,3 Nextbook NXA8QC116B Battery Replacement: 步骤 15 中的图像 2,3 Nextbook NXA8QC116B Battery Replacement: 步骤 15 中的图像 3,3
    • Move the spudger in a left-to-right scraping motion to loosen the glue until the battery is separated from the tablet.
  16. Nextbook NXA8QC116B Battery Replacement: 步骤 16 中的图像 1,1
    • Remove the battery.
结论
3等其他人完成本指南。
一条评论
Where can i buy this battery?
Cell Tech - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 21
总计 4,873
