跳转到主内容
加入维修社区 - 创建账户
Nextbook NX008HD8G Back Panel Replacement
你所需要的
  1. Nextbook NX008HD8G Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,2 Nextbook NX008HD8G Back Panel Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Using your finger, open the plastic tab to the right of the rear-facing camera.
    • Wedge your fingernail in between the back panel and the plastic tab and pull the plastic tab towards your body.
  2. Nextbook NX008HD8G Back Panel Replacement: 步骤 2 中的图像 1,3 Nextbook NX008HD8G Back Panel Replacement: 步骤 2 中的图像 2,3 Nextbook NX008HD8G Back Panel Replacement: 步骤 2 中的图像 3,3
    • Using your finger, remove the SD card by pressing down on top of it (toward the bottom of the device) until you hear a clicking sound.
    • Once the card pops out, use your finger to pull the card completely out of the SD card slot.
  3. Nextbook NX008HD8G Back Panel Replacement: 步骤 3 中的图像 1,3 Nextbook NX008HD8G Back Panel Replacement: 步骤 3 中的图像 2,3 Nextbook NX008HD8G Back Panel Replacement: 步骤 3 中的图像 3,3
    • Remove the 5 mm screw using the Phillips PH00 bit in the iFixit metal Screwdriver.
  4. Nextbook NX008HD8G Back Panel Replacement: 步骤 4 中的图像 1,3 Nextbook NX008HD8G Back Panel Replacement: 步骤 4 中的图像 2,3 Nextbook NX008HD8G Back Panel Replacement: 步骤 4 中的图像 3,3
    • Use the plastic opening tool to separate the back panel by carefully sliding the narrow end of the tool between the front glass and back panel.
    • Use a second plastic opening tool to help pry the front glass from the back panel.
    • You will hear some cracking sounds when separating the front glass from the back panel. That is okay! That is the back panel latches releasing the front glass.
  5. Nextbook NX008HD8G Back Panel Replacement: 步骤 5 中的图像 1,2 Nextbook NX008HD8G Back Panel Replacement: 步骤 5 中的图像 2,2
    • Use your hands to completely separate the rest of the front glass from the back panel.
    • Do not to pull the device apart with too much force. If you do, you may break or bend the back panel.
结论
3等其他人完成本指南。
Philip Gai
于09/22/15注册
792 声望
创作了3篇指南
团队
Baylor, Team 10-15, Williams Fall 2015 Baylor, Team 10-15, Williams Fall 2015 的会员
BU-WILLIAMS-F15S10G15
3 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 18
总计 1,089
