跳转到主内容
Nextbook Flexx 10 Battery Pack Replacement
你所需要的
  1. Nextbook Flexx 10 Battery Pack Replacement, Battery Pack: 步骤 1 中的图像 1,2 Nextbook Flexx 10 Battery Pack Replacement, Battery Pack: 步骤 1 中的图像 2,2
    • To begin, remove the screen from the keyboard.
    • Open the 2-in-1, and hold the screen.
    • Press the silver button at the top of the keyboard.
    • When the screen lifts up, gently lift the screen away from the keyboard.
  2. Nextbook Flexx 10 Battery Pack Replacement: 步骤 2 中的图像 1,3 Nextbook Flexx 10 Battery Pack Replacement: 步骤 2 中的图像 2,3 Nextbook Flexx 10 Battery Pack Replacement: 步骤 2 中的图像 3,3
    • Removing the back cover will invalidate your warranty.
    • You may use your fingers, or a spudger. Be careful not to break your cover OR your fingernail. Removing the cover requires good judgement.
    • The goal is to separate the black from the silver. Start in a corner, or a flat edge -- whichever works best for you. Remember to not use too much force.
    • Once you start the initial separation, keep going until you free one edge. The goal now is to free three edges of the rectangle.
    • If your progress stops on one side of the rectangle, go to the other side and try there.
  3. Nextbook Flexx 10 Battery Pack Replacement: 步骤 3 中的图像 1,1
    • Gently pull the back cover from the screen assembly.
    • Keep the plastic cover close. It's great for holding screws!
    • When putting the cover back on, press firmly around to outside edge with the screen facing down on a flat, debris-free surface.
  4. Nextbook Flexx 10 Battery Pack Replacement: 步骤 4 中的图像 1,1
    • Once you have the cover off, remove the screws from the outer perimeter of the board assembly with a small philips head screwdriver. See arrows.
  5. Nextbook Flexx 10 Battery Pack Replacement: 步骤 5 中的图像 1,3 Nextbook Flexx 10 Battery Pack Replacement: 步骤 5 中的图像 2,3 Nextbook Flexx 10 Battery Pack Replacement: 步骤 5 中的图像 3,3
    • Remove the smaller ribbon clip on the right side of the device and top right of the battery.
    • Remove the second clip underneath the ribbon clip.
  6. Nextbook Flexx 10 Battery Pack Replacement: 步骤 6 中的图像 1,3 Nextbook Flexx 10 Battery Pack Replacement: 步骤 6 中的图像 2,3 Nextbook Flexx 10 Battery Pack Replacement: 步骤 6 中的图像 3,3
    • When removing the second cable clip use a small flat head screw driver to lift the latch.
    • when removing be careful not to damage the ribbon cable.
  7. Nextbook Flexx 10 Battery Pack Replacement: 步骤 7 中的图像 1,2 Nextbook Flexx 10 Battery Pack Replacement: 步骤 7 中的图像 2,2
    • Repeat step 6 for the large ribbon cable.
  8. Nextbook Flexx 10 Battery Pack Replacement: 步骤 8 中的图像 1,3 Nextbook Flexx 10 Battery Pack Replacement: 步骤 8 中的图像 2,3 Nextbook Flexx 10 Battery Pack Replacement: 步骤 8 中的图像 3,3
    • To remove the battery section of the device from the circuit board remove, use the small Phillips head screwdriver for the 3 small screws near the top.
    • To get the battery pack completely away from the circuit board there is copper foil on the back of the battery.
    • be careful not to rip the copper foil. Pull the foil slowly an evenly.
  9. Nextbook Flexx 10 Battery Pack Replacement: 步骤 9 中的图像 1,3 Nextbook Flexx 10 Battery Pack Replacement: 步骤 9 中的图像 2,3 Nextbook Flexx 10 Battery Pack Replacement: 步骤 9 中的图像 3,3
    • Now that the battery is all by itself find a non-sharp and thin object to help pry the battery from its base.
    • Move slowly and carefully to not puncher the battery casing.
    • FINALLY you have successfully removed the battery from your device.
结论
4等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 45
总计 4,493
