跳转到主内容
加入维修社区 - 创建账户
Nextbook 8 Camera Replacement
你所需要的
  1. Nextbook 8 Camera Replacement, Battery: 步骤 1 中的图像 1,2 Nextbook 8 Camera Replacement, Battery: 步骤 1 中的图像 2,2
    • Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
    • Slide the tool along the edge to work the back cover off.
    • It helps to have an extra tool to stick in the gap and keep the back cover separated from the glass as you slide the other tool.
    添加评论
  2. Nextbook 8 Camera Replacement: 步骤 2 中的图像 1,2 Nextbook 8 Camera Replacement: 步骤 2 中的图像 2,2
    • Remove the tape covering the motherboard.
    • Remove the silver tape holding the white ribbon cables to the battery.
    询问修复机器人
    添加评论
  3. Nextbook 8 Camera Replacement: 步骤 3 中的图像 1,2 Nextbook 8 Camera Replacement: 步骤 3 中的图像 2,2
    • Use a spudger to carefully disconnect the battery connector from the motherboard.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    添加评论
  4. Nextbook 8 Camera Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    • Use a spudger to lift up the black bar on the two ZIF connectors located above the battery.
    • Pull the ribbon cables out of the connectors with tweezers or two fingers.
    询问修复机器人
    添加评论
  5. Nextbook 8 Camera Replacement: 步骤 5 中的图像 1,2 Nextbook 8 Camera Replacement: 步骤 5 中的图像 2,2
    • Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
    • The battery is very malleable, so do not try to pull it off all at once.
    添加评论
  6. Nextbook 8 Camera Replacement, Camera: 步骤 6 中的图像 1,1
    • Slowly pull up masking tape by pulling down from the top.
    • Be careful because both the front and rear cameras are attached to each other.
    询问修复机器人
    添加评论
  7. Nextbook 8 Camera Replacement: 步骤 7 中的图像 1,1
    • Peel the bottom part of the masking tape off to reveal the ribbon connector.
    询问修复机器人
    添加评论
  8. Nextbook 8 Camera Replacement: 步骤 8 中的图像 1,1
    • Pull both camera lenses out of the holes.
    询问修复机器人
    添加评论
  9. Nextbook 8 Camera Replacement: 步骤 9 中的图像 1,1
    • Use a spudger to disconnect the two camera lenses from the device.
    • Carefully lift the black connector to release the cameras.
    询问修复机器人
    添加评论
  10. Nextbook 8 Camera Replacement: 步骤 10 中的图像 1,1
    • Pull both camera lenses out of the ribbon connector.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Dylan Wiese
于03/11/15注册
1,889 声望
创作了5篇指南
团队
Colorado Springs, Team 5-1, Panko Spring 2015 Colorado Springs, Team 5-1, Panko Spring 2015 的会员
UCCS-PANKO-S15S5G1
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 11
过去 30 天: 42
总计 1,547
