跳转到主内容
加入维修社区 - 创建账户
Nextbook 8 Battery Replacement
你所需要的
  1. Nextbook 8 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Nextbook 8 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
    • Slide the tool along the edge to work the back cover off.
    • It helps to have an extra tool to stick in the gap and keep the back cover separated from the glass as you slide the other tool.
    添加评论
  2. Nextbook 8 Battery Replacement: 步骤 2 中的图像 1,2 Nextbook 8 Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the tape covering the motherboard.
    • Remove the silver tape holding the white ribbon cables to the battery.
    询问修复机器人
    添加评论
  3. Nextbook 8 Battery Replacement: 步骤 3 中的图像 1,2 Nextbook 8 Battery Replacement: 步骤 3 中的图像 2,2
    • Use a spudger to carefully disconnect the battery connector from the motherboard.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    添加评论
  4. Nextbook 8 Battery Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    • Use a spudger to lift up the black bar on the two ZIF connectors located above the battery.
    • Pull the ribbon cables out of the connectors with tweezers or two fingers.
    询问修复机器人
    添加评论
  5. Nextbook 8 Battery Replacement: 步骤 5 中的图像 1,2 Nextbook 8 Battery Replacement: 步骤 5 中的图像 2,2
    • Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
    • The battery is very malleable, so do not try to pull it off all at once.
    添加评论
结论
取消:我没有完成这个指南。
24等其他人完成本指南。
Dylan Wiese
于03/11/15注册
1,889 声望
创作了5篇指南
团队
Colorado Springs, Team 5-1, Panko Spring 2015 Colorado Springs, Team 5-1, Panko Spring 2015 的会员
UCCS-PANKO-S15S5G1
3 名成员
创作了10篇指南
5指南评论
Very helpful and well made.
Quentin Freed - 回复 分享
Where can I buy the battery???
scruff67 - 回复 分享
Check Ebay. That's where I'm headed right now.
Tina Carey - 回复 分享
im having connection issues i cant find any wifi period
crusher309 - 回复 分享
Hello,
Yes well, but what is th voltage battery?
Thanks
Tyeroued - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 59
总计 43,246
