跳转到主内容
NexiGo NS32 Vibration Motor Replacement
你所需要的
  1. NexiGo NS32 Vibration Motor Replacement, Rear Case: 步骤 1 中的图像 1,1
    • Orient the controller so that it is face down.
  2. NexiGo NS32 Vibration Motor Replacement: 步骤 2 中的图像 1,2 NexiGo NS32 Vibration Motor Replacement: 步骤 2 中的图像 2,2
    • Remove the eight 9 mm Phillips screws that secure the rear case.
  3. NexiGo NS32 Vibration Motor Replacement: 步骤 3 中的图像 1,1
    • Lift the rear case up and off.
    • You may need to use an opening tool to help release the rear case, but avoid using excessive force so you don't damage the controller.
  4. NexiGo NS32 Vibration Motor Replacement, Vibration Motor: 步骤 4 中的图像 1,3 NexiGo NS32 Vibration Motor Replacement, Vibration Motor: 步骤 4 中的图像 2,3 NexiGo NS32 Vibration Motor Replacement, Vibration Motor: 步骤 4 中的图像 3,3
    • Grip the white vibration motor connections and pull them directly out of their sockets.
  5. NexiGo NS32 Vibration Motor Replacement: 步骤 5 中的图像 1,2 NexiGo NS32 Vibration Motor Replacement: 步骤 5 中的图像 2,2
    • Gently lift out the vibration motors.
    • The vibration motors may be glued in place. If you're having trouble removing them, apply some high-concentration isopropyl alcohol to loosen the adhesive.
结论
Naiza Hall
于01/29/24注册
265 声望
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 83
