跳转到主内容
NexiGo NS32 Trigger Assembly Replacement
你所需要的
  1. NexiGo NS32 Trigger Assembly Replacement, Rear Case: 步骤 1 中的图像 1,1
    • Orient the controller so that it is face down.
  2. NexiGo NS32 Trigger Assembly Replacement: 步骤 2 中的图像 1,2 NexiGo NS32 Trigger Assembly Replacement: 步骤 2 中的图像 2,2
    • Remove the eight 9 mm Phillips screws that secure the rear case.
  3. NexiGo NS32 Trigger Assembly Replacement: 步骤 3 中的图像 1,1
    • Lift the rear case up and off.
    • You may need to use an opening tool to help release the rear case, but avoid using excessive force so you don't damage the controller.
  4. NexiGo NS32 Trigger Assembly Replacement, Battery: 步骤 4 中的图像 1,2 NexiGo NS32 Trigger Assembly Replacement, Battery: 步骤 4 中的图像 2,2
    • Grip the white battery connector and pull it directly out of its motherboard socket.
    • This may require some force, as the connectors are secured with a bit of adhesive. If you're having trouble with disconnection, apply some high-concentration isopropyl alcohol to the adhesive to loosen it.
    • Do not pull on the wires.
  5. NexiGo NS32 Trigger Assembly Replacement: 步骤 5 中的图像 1,3 NexiGo NS32 Trigger Assembly Replacement: 步骤 5 中的图像 2,3 NexiGo NS32 Trigger Assembly Replacement: 步骤 5 中的图像 3,3
    • Lift the battery up and out.
    • Take care not to bend or puncture the battery as you remove it.
  6. NexiGo NS32 Trigger Assembly Replacement, Joystick PCB: 步骤 6 中的图像 1,2 NexiGo NS32 Trigger Assembly Replacement, Joystick PCB: 步骤 6 中的图像 2,2
    • Remove the three 9 mm Phillips screws that secure the joystick PCB.
  7. NexiGo NS32 Trigger Assembly Replacement: 步骤 7 中的图像 1,2 NexiGo NS32 Trigger Assembly Replacement: 步骤 7 中的图像 2,2
    • Flip up the black ZIF connector locking flap on the left side of the joystick PCB.
    • Pull the ribbon cable directly out of its socket.
  8. NexiGo NS32 Trigger Assembly Replacement: 步骤 8 中的图像 1,3 NexiGo NS32 Trigger Assembly Replacement: 步骤 8 中的图像 2,3 NexiGo NS32 Trigger Assembly Replacement: 步骤 8 中的图像 3,3
    • Lift out the joystick PCB.
  9. NexiGo NS32 Trigger Assembly Replacement, Trigger Assembly: 步骤 9 中的图像 1,1
    • Flip up the black ZIF locking flap that secures the trigger assembly ribbon cable.
    • Disconnect the ribbon cable.
  10. NexiGo NS32 Trigger Assembly Replacement: 步骤 10 中的图像 1,2 NexiGo NS32 Trigger Assembly Replacement: 步骤 10 中的图像 2,2
    • Gently lift out the trigger assembly.
结论
Gage_Atx
于01/29/24注册
85 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 118
