跳转到主内容
加入维修社区 - 创建账户
Newport e500 Internal Battery Disassembly
医疗设备
iFixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
你所需要的
  1. Newport e500 Internal Battery  Disassembly, Newport e500 Top Cover Disassembly: 步骤 1 中的图像 1,1
    • Place device so that the top cover is facing you.
    • Open the top cover.
  2. Newport e500 Internal Battery  Disassembly: 步骤 2 中的图像 1,1
    • Remove the four hex nuts and lock washers (two at each hinge) that secure the cover to the hinges on the left side of the pneumatic box.
  3. Newport e500 Internal Battery  Disassembly: 步骤 3 中的图像 1,1
    • Remove the cover and set aside. Retain hardware for re-assembly.
  4. Newport e500 Internal Battery  Disassembly, Newport e500 Exhalation Module Disassembly: 步骤 4 中的图像 1,1
    • Pull up and remove the flexible rubber exhalation outlet boot (push fit).
  5. Newport e500 Internal Battery  Disassembly: 步骤 5 中的图像 1,1
    • Disconnect the tubes from both sides of the flow sensor and the two tubes from the exhalation valve.
  6. Newport e500 Internal Battery  Disassembly: 步骤 6 中的图像 1,1
    • Pull the exhalation module straight up to remove it from the GDU.
  7. Newport e500 Internal Battery  Disassembly, Newport e500 Internal Battery  Disassembly: 步骤 7 中的图像 1,1
    • Remove the two nuts that hold the battery cover to the electronics box assembly and remove the cover.
  8. Newport e500 Internal Battery  Disassembly: 步骤 8 中的图像 1,1
    • Disconnect the black and red wires from the battery terminals.
  9. Newport e500 Internal Battery  Disassembly: 步骤 9 中的图像 1,1
    • Pull the battery from the electronics box assembly.
结论
Jeremy
于04/07/20注册
589 声望
创作了6篇指南
团队
Cal Poly, Team S7-G16, Paton Spring 2020 Cal Poly, Team S7-G16, Paton Spring 2020 的会员
CPSU-PATON-S20S7G16
3 名成员
创作了13篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 235
