跳转到主内容
Newport e500 Analog PCB Disassembly
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
你所需要的
  1. Newport e500 Analog PCB Disassembly, Newport e500 Top Cover Disassembly: 步骤 1 中的图像 1,1
    • Place device so that the top cover is facing you.
    • Open the top cover.
  2. Newport e500 Analog PCB Disassembly: 步骤 2 中的图像 1,1
    • Remove the four hex nuts and lock washers (two at each hinge) that secure the cover to the hinges on the left side of the pneumatic box.
  3. Newport e500 Analog PCB Disassembly: 步骤 3 中的图像 1,1
    • Remove the cover and set aside. Retain hardware for re-assembly.
  4. Newport e500 Analog PCB Disassembly, Newport e500 Exhalation Module Disassembly: 步骤 4 中的图像 1,1
    • Pull up and remove the flexible rubber exhalation outlet boot (push fit).
  5. Newport e500 Analog PCB Disassembly: 步骤 5 中的图像 1,1
    • Disconnect the tubes from both sides of the flow sensor and the two tubes from the exhalation valve.
  6. Newport e500 Analog PCB Disassembly: 步骤 6 中的图像 1,1
    • Pull the exhalation module straight up to remove it from the GDU.
  7. Newport e500 Analog PCB Disassembly, Newport e500 Air and Oxygen Flow Sensors Disassembly: 步骤 7 中的图像 1,1
    • Remove the 2 screws and washers securing the manifold/mixer assembly
  8. Newport e500 Analog PCB Disassembly: 步骤 8 中的图像 1,1
    • Slide the manifold/mixer assembly forward to disengage the flow sensors
  9. Newport e500 Analog PCB Disassembly: 步骤 9 中的图像 1,1
    • Gently pull each flow sensor straight out from the servo valve, (the flow sensor push-fits into the servo valve port).
  10. Newport e500 Analog PCB Disassembly: 步骤 10 中的图像 1,1
    • Disconnect the flow sensor cable from its 10 pin connector at the underside of the flow sensor PCB and lift out the flow sensor.
  11. Newport e500 Analog PCB Disassembly, Newport e500 Pneumatic Panel Disassembly: 步骤 11 中的图像 1,1
    • Remove the screw and washer that secure the exhalation manifold support to the pneumatic panel.
  12. Newport e500 Analog PCB Disassembly: 步骤 12 中的图像 1,1
    • Pull up on the exhalation valve guide block to remove it from the pneumatic box.
  13. Newport e500 Analog PCB Disassembly: 步骤 13 中的图像 1,1
    • Remove the standoff and five screws and washers that secure the pneumatic panel to the pneumatic box.
  14. Newport e500 Analog PCB Disassembly: 步骤 14 中的图像 1,1
    • Lift the pneumatic panel out of the box, and from the underside, detach all tubes and the heater wires that connect to the analog PCB.
  15. Newport e500 Analog PCB Disassembly, Newport e500 Analog PCB Disassembly: 步骤 15 中的图像 1,1
    • Remove the cable from the connector J1 on the analog PCB.
  16. Newport e500 Analog PCB Disassembly: 步骤 16 中的图像 1,1
    • Carefully pull the tubes from each of the seven transducers on the analog PCB. Take note of the tubing connections for re-assembly.
  17. Newport e500 Analog PCB Disassembly: 步骤 17 中的图像 1,1
    • Disconnect the J4 connector from the analog PCB.
  18. Newport e500 Analog PCB Disassembly: 步骤 18 中的图像 1,1
    • Remove the four screws and washers that hold the analog PCB to the pneumatic box assembly.
  19. Newport e500 Analog PCB Disassembly: 步骤 19 中的图像 1,1
    • Hold tubing aside and remove analog PCB from the box assembly.
结论
Seth Aguilar
于01/24/19注册
360 声望
创作了3篇指南
团队
Cal Poly, Team S7-G16, Paton Spring 2020 Cal Poly, Team S7-G16, Paton Spring 2020 的会员
CPSU-PATON-S20S7G16
3 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 97
