跳转到主内容
Newport HT70 Plus Ventilator Air Intake Filter Replacement
你所需要的
  1. Newport HT70 Plus Ventilator Air Intake Filter Replacement, Air intake Filter: 步骤 1 中的图像 1,1
    • Make sure that the Ventilator is turned OFF. The power switch is located in the back side of the ventilator.
    • Remove the Power Cord.
  2. Newport HT70 Plus Ventilator Air Intake Filter Replacement: 步骤 2 中的图像 1,3 Newport HT70 Plus Ventilator Air Intake Filter Replacement: 步骤 2 中的图像 2,3 Newport HT70 Plus Ventilator Air Intake Filter Replacement: 步骤 2 中的图像 3,3
    • Locate the right panel of the Ventilator.
    • Remove the Air O2 mixer by rotating it counterclockwise, and then pull the mixer out.
  3. Newport HT70 Plus Ventilator Air Intake Filter Replacement: 步骤 3 中的图像 1,1
    • Remove the two thumbscrews by twisting then counterclockwise.
    • Remove the filter cover. Use a prying tool if needed.
  4. Newport HT70 Plus Ventilator Air Intake Filter Replacement: 步骤 4 中的图像 1,2 Newport HT70 Plus Ventilator Air Intake Filter Replacement: 步骤 4 中的图像 2,2
    • Replace the old filter with the new one.
    • Once replaced, place back the Filter cover.
    • Screw the thumbscrews back into place, fastening them clockwise.
  5. Newport HT70 Plus Ventilator Air Intake Filter Replacement: 步骤 5 中的图像 1,1
    • Run a Circuit Check before you install the air O2 mixer back into place.
    • Place back the air O2 mixer by adjusting the flanges into the proper position. And then rotate the air mixer clockwise to lock into place.
结论
另外一个人完成了本指南。
Jorge Castillo
于04/10/20注册
201 声望
撰写一个指南
团队
Cal Poly, Team S7-G5, Paton Spring 2020 Cal Poly, Team S7-G5, Paton Spring 2020 的会员
CPSU-PATON-S20S7G5
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 363
