简介
According to the service manual the Air Intake Filter should be checked weekly while in use. In some environments, it may need to be checked more often. The filter should be replaced when the majority of the filter surface area is no longer white. Air Intake Filters are not reusable.
PLEASE NOTE: This repair guide was developed by the iFixit team based on Newport's own service manual. Neither iFixit nor this repair guide is endorsed by or affiliated with Newport.
Replacing the air inlet filter is discussed in:
- chapter 8-3 “Cleaning and Maintenance - Air Intake Filter” of user manual
- chapter 5-7 “Service and Repair - Air Inlet Filter” of service manual
The momentary-type power switch is located on the left side rear of the ventilator along the bottom edge. Press the power switch once.
A message appears in the screen that prompts you to Press Accept to Shutdown or Press Cancel to Ignore.
Pressing the Accept button will power off the ventilator.
Pressing Cancel will return the ventilator to its previous state.
Press Alarm Silence to silence the Shut Down alarm.
The inlet air filter is located on the right-hand side of the device.
Turn the knurled screws counter-clockwise to remove.
Slide the inlet filter cover assembly toward the back of the device and lift it out.
Remove the Air Inlet Filter Gasket by carefully pulling it away from the side of the device.
Slide the air filter cover back on.
Turn the knurled screws clockwise to insert.
- Connect the ventilator back to the AC power.
- Turn the ventilator back on into standby mode by pressing the power switch once.
- While in standby mode you can make settings changes and perform the Circuit Check prior to ventilation.
另外一个人完成了本指南。
