跳转到主内容
New Speed 26-inch Electric Bike Throttle Replacement
你所需要的
  1. New Speed 26-inch Electric Bike Throttle Replacement, Electric Bike Throttle: 步骤 1 中的图像 1,1
    • Remove the 3/32" Allen screw from the top of the throttle.
    • When removing the screw, make sure the wrench is well seated to avoid damaging the screw.
    • Make sure that your bike's power is turned off before beginning to disassemble it.
  2. New Speed 26-inch Electric Bike Throttle Replacement: 步骤 2 中的图像 1,1
    • Remove the 5/64" Allen screw from the underside of the throttle.
  3. New Speed 26-inch Electric Bike Throttle Replacement: 步骤 3 中的图像 1,1
    • Slide the throttle off of the handlebar.
    • Be careful when removing the throttle. Taking it off too quickly could result in damage to the wiring.
  4. New Speed 26-inch Electric Bike Throttle Replacement: 步骤 4 中的图像 1,1
    • Remove the two 2mm Phillips screws from the back of the control box.
    • Repeat this process for the other side of the control box. 4 screws will be removed in total.
  5. New Speed 26-inch Electric Bike Throttle Replacement: 步骤 5 中的图像 1,1
    • Open the control box.
  6. New Speed 26-inch Electric Bike Throttle Replacement: 步骤 6 中的图像 1,2 New Speed 26-inch Electric Bike Throttle Replacement: 步骤 6 中的图像 2,2
    • Unwrap the cable lining surrounding the throttle cable.
    • Track the throttle cable to the control box.
    • Disconnect the JST-SM connector from the main controller.
    • Take caution while handling these wires. They can be easily damaged.
  7. New Speed 26-inch Electric Bike Throttle Replacement: 步骤 7 中的图像 1,2 New Speed 26-inch Electric Bike Throttle Replacement: 步骤 7 中的图像 2,2
    • Cut the zip ties found along the frame of the bike.
    • Remove the throttle and its wires from the frame of the bike.
    • Be careful not to cut too close to the wires, as you could risk damaging them or hurting yourself.
结论
To reassemble your device, follow the steps in reverse order.
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 43
总计 751
