跳转到主内容
NeuTab N9 Camera Replacement
你所需要的
  1. NeuTab N9 Camera Replacement, Camera: 步骤 1 中的图像 1,1
    • Turn off your device before beginning these steps.
    • Insert the plastic opening tool into the seam between the screen and the back of the tablet. Move the opening tool along the seam until the back of the tablet releases.
  2. NeuTab N9 Camera Replacement: 步骤 2 中的图像 1,2 NeuTab N9 Camera Replacement: 步骤 2 中的图像 2,2
    • Locate your camera in the corner of your tablet, connected to the circuit board.
    • Insert your plastic opening tool into the clip that secures the camera ribbon to the circuit board. Gently pry up until the clip releases its hold on the ribbon.
  3. NeuTab N9 Camera Replacement: 步骤 3 中的图像 1,1
    • The rear-facing camera module of the tablet is secured to the device with a strong adhesive. Insert your plastic opening tool underneath the rear-facing camera module and gently pry it up until it is released from the glue. You may now remove the entire camera assembly.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 7
总计 92
