跳转到主内容
加入维修社区 - 创建账户
Network card Replacement
你所需要的
  1. Network card Replacement, Remove battery: 步骤 1 中的图像 1,1
    • Be sure to remove the battery to prevent any electrical shortage.
  2. Network card Replacement, Remove the backpanel: 步骤 2 中的图像 1,2 Network card Replacement, Remove the backpanel: 步骤 2 中的图像 2,2
    • Loosen all four screws and remove the back panel.
    • Remove the back panel with a spudger. Start out as in the second photo to prevent the plastic from breaking. Work you're way around the panel to remove it.
  3. Network card Replacement, Remove the antenna wires: 步骤 3 中的图像 1,2 Network card Replacement, Remove the antenna wires: 步骤 3 中的图像 2,2
    • In the red circle is the network card
    • Remove the two wires (inside the green circle)
    • the wires are very fragile and need to be removed with care
  4. Network card Replacement, Remove the network card: 步骤 4 中的图像 1,1
    • Place the spudger as shown in the photo. The network card will pop up. After that you can remove it and replace it with another one
    • The wires are very fragile, be aware!
结论
To reassemble your device, follow these instructions in reverse order. Be sure to connect the wires the same as in step 3.
2等其他人完成本指南。
Robin Koch
于03/25/17注册
289 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 897
