跳转到主内容
加入维修社区 - 创建账户
Network Card
你所需要的
  1. Network Card, Bottom Cover: 步骤 1 中的图像 1,1
    • Use a Philips J1 driver to remove eight screws securing the bottom case.
    • Remove all of the 8 screws and the bottom panel should pop off.
  2. Network Card: 步骤 2 中的图像 1,1
    • After that you are in and now can change most of the components, which we also have tutorials for.
  3. Network Card, Network Card: 步骤 3 中的图像 1,1
    • Remove the screw with a Philips J1 driver.
    • Try to remove the cables by hand or if you really can't, then use a spudger to carefully pry them up.
    • After removing the screw and the cables, you can safely remove the network card.
  4. Network Card: 步骤 4 中的图像 1,1
    • If you need to change the Wireless card and nothing else then now is the time to do so.
    • After the previous step, you are good to go.
结论
另外一个人完成了本指南。
Regome
于01/20/23注册
794 声望
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 154
