跳转到主内容
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的Nighthawk AX8 8-Stream AX6000 WiFi Router,应参考我们的维修指南
  1. Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown, Fold wings down: 步骤 1 中的图像 1,1
    • Lift each antenna wing up and then fold it down, like how the router was when it was first removed from the box.
  2. Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown, Remove bottom pads and screws: 步骤 2 中的图像 1,1
    • Remove the four rubber pads, and then remove the four Torx T10 screws underneath those pads.
    • Note: You will feel a divot underneath the serial number sticker, but there is no hidden screw. You do not need to remove or damage the sticker.
  3. Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown, Remove antenna wing screws: 步骤 3 中的图像 1,1
    • Flip the router over again.
    • Remove the left-most and right-most Torx T7 screws from both antenna wings.
  4. Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown, Remove bottom plate: 步骤 4 中的图像 1,1
    • Flip the router again.
    • Pull the bottom plate upwards to remove it.
  5. Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown, Remove wire tape: 步骤 5 中的图像 1,1
    • Note: The router's mainboard is no longer secured to the shell, but attempting to remove it could damage the antenna wires and ribbon cable.
    • The antenna and fan wires are secured with tape.
    • Use tweezers to lift each piece of tape off.
  6. Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown, Disconnect antenna wires: 步骤 6 中的图像 1,2 Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown, Disconnect antenna wires: 步骤 6 中的图像 2,2
    • Each antenna is plugged into the mainboard with a simple snap connector.
    • Lift off each snap connector with your fingers or a plastic spudger. It is recommended you label these in order from top to bottom so assembly is easy.
    • The antenna wires are also run through 'teeth' on the board. Pull the wires out of each tooth.
  7. Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown, Disconnect ribbon cable: 步骤 7 中的图像 1,1
    • You will find a ribbon cable connected to the mainboard in the lower-right corner.
    • Use a thin spudger or fingernail to flip the small black clip up. It does not fold over completely to the left, and do not attempt to force it.
    • Pull the ribbon cable out to the right.
  8. Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown, Remove mainboard from shell: 步骤 8 中的图像 1,1
    • Tilt the mainboard upwards towards the ethernet ports.
    • Pull the mainboard slightly forwards from the ethernet ports. The board should slide out with ease.
  9. Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown, Disconnect fan: 步骤 9 中的图像 1,1
    • Flip the mainboard over so that the heat sink and fan are facing you.
    • Locate the fan connector in the upper-left of the mainboard.
    • Pull the fan connector upwards.
  10. Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown, Remove heat sink screws: 步骤 10 中的图像 1,1
    • Flip the mainboard over again so that the underside is facing you.
    • Use a Torx T10 bit to remove the six screws.
  11. Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown, Remove the heat sink: 步骤 11 中的图像 1,1
    • Flip the mainboard over again so the heat sink and fan are facing you. The components will not detach as the mainboard and heat sink are stuck together with thermal pads.
    • You will have to use a fair amount of pressure to remove the heat sink from the mainboard.
    • You will hear a peeling or tearing sound, but this is just the sticky thermal pads releasing from the PCB shields on the mainboard.
  12. Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown, Heat sink and mainboard separated: 步骤 12 中的图像 1,1
    • This is the heat sink and mainboard sitting side by side
    • The metal components on the mainboard are PCB shields. These are soldered into place.
    • The thermal pads for the lower two PCB shields are thicker, and sit in a divot in the shield.
    • The thermal pad for the upper PCB shield are thinner, and just touch the shield instead of sitting in a divot.
    • The thermal pad in the middle of the board is only for extra stability.
  13. Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown, Remove fan: 步骤 13 中的图像 1,1
    • The 55mm fan can be removed from the underside of the heat sink.
    • Flip the heatsink over so that the thermal pads are facing you.
    • Remove the two thermal pads covering the fan screws.
    • Use a Torx T10 bit to remove the fan screws.
Matt Zulawski
于10/02/17注册
217 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 20
总计 374
