跳转到主内容
加入维修社区 - 创建账户
Netgear Arlo Plastic Housing Replacement
你所需要的
    1. Netgear Arlo Plastic Housing Replacement, Battery: 步骤 1 中的图像 1,3 Netgear Arlo Plastic Housing Replacement, Battery: 步骤 1 中的图像 2,3 Netgear Arlo Plastic Housing Replacement, Battery: 步骤 1 中的图像 3,3
      • Locate unlock switch on underside of camera and unlock it by sliding it.
      • Once unlocked, slide the cover out and up to open the battery housing.
      询问修复机器人
      添加评论
    2. Netgear Arlo Plastic Housing Replacement: 步骤 2 中的图像 1,1
      • Remove all 4 of the 3.0 Volt batteries from the battery housing.
      询问修复机器人
      添加评论
    3. Netgear Arlo Plastic Housing Replacement: 步骤 3 中的图像 1,1
      • Inspect prongs at the bottom of the battery housing to ensure that they are not bent or broken before replacing the batteries.
      询问修复机器人
      添加评论
    1. Netgear Arlo Plastic Housing Replacement, Plastic Housing: 步骤 4 中的图像 1,1
      • Remove the 2 (3.5mm) housing screws with a J0 screwdriver.
      询问修复机器人
      添加评论
    2. Netgear Arlo Plastic Housing Replacement: 步骤 5 中的图像 1,2 Netgear Arlo Plastic Housing Replacement: 步骤 5 中的图像 2,2
      • Slide the unlocked battery cover forward to remove 2 (3.5mm) screws, that are behind the cover.
      询问修复机器人
      添加评论
    3. Netgear Arlo Plastic Housing Replacement: 步骤 6 中的图像 1,1
      • Open the battery cover and remove the 2 (3.5mm") screws from under the cover.
      询问修复机器人
      添加评论
    4. Netgear Arlo Plastic Housing Replacement: 步骤 7 中的图像 1,3 Netgear Arlo Plastic Housing Replacement: 步骤 7 中的图像 2,3 Netgear Arlo Plastic Housing Replacement: 步骤 7 中的图像 3,3
      • Use a plastic opening tool to start separating the plastic housing from the front side of the battery cover.
      • Next, start separating the plastic cover from the rear of the plastic housing, and work your way down the seam line.
      • Make sure the plastics snaps on the front of the plastic get unhooked from the grey plastic ring around the front of the camera.
      询问修复机器人
      添加评论
    5. Netgear Arlo Plastic Housing Replacement: 步骤 8 中的图像 1,3 Netgear Arlo Plastic Housing Replacement: 步骤 8 中的图像 2,3 Netgear Arlo Plastic Housing Replacement: 步骤 8 中的图像 3,3
      • Remove the screw (3.5mm) near the sync button holding the opposite side of the camera on.
      • Remove the second screw (3.5mm) on the back of the camera to remove the second housing.
      • Once the screws are removed use an opening tool to pry back the second plastic mount.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
IUPUI, Team S1-G1, Freund Spring 2018 IUPUI, Team S1-G1, Freund Spring 2018 的会员
IUPUI-FREUND-S18S1G1
2 名成员
创作了21篇指南
2指南评论
Where can I buy replacement parts like a battery cover for Arlo
L R Hardy - 回复 分享
Note that under the rubber cover shown in step 6 there is a USB-B port.
You can run the Arlo on a USB adapter as well.
You only need to make a hole in the battery lid or 3D print a new cover.
Bas Vijfwinkel - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 45
总计 2,961
