跳转到主内容
加入维修社区 - 创建账户
Netgear Arlo Charging Port Replacement
你所需要的
    1. Netgear Arlo Charging Port Replacement, Plastic Housing: 步骤 1 中的图像 1,1
      • Remove the 2 (3.5mm) housing screws with a J0 screwdriver.
      询问修复机器人
      添加评论
    2. Netgear Arlo Charging Port Replacement: 步骤 2 中的图像 1,2 Netgear Arlo Charging Port Replacement: 步骤 2 中的图像 2,2
      • Slide the unlocked battery cover forward to remove 2 (3.5mm) screws, that are behind the cover.
      询问修复机器人
      添加评论
    3. Netgear Arlo Charging Port Replacement: 步骤 3 中的图像 1,1
      • Open the battery cover and remove the 2 (3.5mm") screws from under the cover.
      询问修复机器人
      添加评论
    4. Netgear Arlo Charging Port Replacement: 步骤 4 中的图像 1,3 Netgear Arlo Charging Port Replacement: 步骤 4 中的图像 2,3 Netgear Arlo Charging Port Replacement: 步骤 4 中的图像 3,3
      • Use a plastic opening tool to start separating the plastic housing from the front side of the battery cover.
      • Next, start separating the plastic cover from the rear of the plastic housing, and work your way down the seam line.
      • Make sure the plastics snaps on the front of the plastic get unhooked from the grey plastic ring around the front of the camera.
      询问修复机器人
      添加评论
    5. Netgear Arlo Charging Port Replacement: 步骤 5 中的图像 1,3 Netgear Arlo Charging Port Replacement: 步骤 5 中的图像 2,3 Netgear Arlo Charging Port Replacement: 步骤 5 中的图像 3,3
      • Remove the screw (3.5mm) near the sync button holding the opposite side of the camera on.
      • Remove the second screw (3.5mm) on the back of the camera to remove the second housing.
      • Once the screws are removed use an opening tool to pry back the second plastic mount.
      询问修复机器人
      添加评论
    1. Netgear Arlo Charging Port Replacement, Lens Assembly: 步骤 6 中的图像 1,1
      • Remove 4 (6mm) large screws with a J00 screwdriver.
      • There are 2 on each side. This will allow you to remove the clear housing from the white housing.
      询问修复机器人
      添加评论
    2. Netgear Arlo Charging Port Replacement: 步骤 7 中的图像 1,2 Netgear Arlo Charging Port Replacement: 步骤 7 中的图像 2,2
      • Once screws are removed, pull apart the clear housing.
      • Remove rod from camera cover.
      询问修复机器人
      添加评论
    3. Netgear Arlo Charging Port Replacement: 步骤 8 中的图像 1,3 Netgear Arlo Charging Port Replacement: 步骤 8 中的图像 2,3 Netgear Arlo Charging Port Replacement: 步骤 8 中的图像 3,3
      • Remove Large ribbon cable first to disconnect front of camera from main body.
      • Remove 4 (3.5mm) small black screws from motherboard of the camera unit.
      • Remove smaller ribbon cable from underneath yellow tape.
      添加评论
    4. Netgear Arlo Charging Port Replacement: 步骤 9 中的图像 1,1
      • Once all ribbon cables are removed, remove the motherboard and camera assembly by pulling up on the black camera motherboard.
      询问修复机器人
      添加评论
    1. Netgear Arlo Charging Port Replacement, Charging Port: 步骤 10 中的图像 1,1
      • Remove the 2 (.135") housing screws with a JIS00 screwdriver
      询问修复机器人
      添加评论
    2. Netgear Arlo Charging Port Replacement: 步骤 11 中的图像 1,1
      • Remove 4 (.135") screws on the inside of the battery compartment using the JIS 00 screwdriver.
      询问修复机器人
      添加评论
    3. Netgear Arlo Charging Port Replacement: 步骤 12 中的图像 1,1
      • Slide the two halves apart
      询问修复机器人
      添加评论
    4. Netgear Arlo Charging Port Replacement: 步骤 13 中的图像 1,1
      • Remove the 2 (.135") screws holding the charging port on using the JIS 00 screwdriver.
      询问修复机器人
      添加评论
    5. Netgear Arlo Charging Port Replacement: 步骤 14 中的图像 1,2 Netgear Arlo Charging Port Replacement: 步骤 14 中的图像 2,2
      • Remove the ribbon by prying the black ribbon holder up using the opening tool.
      • Pull the ribbon away from the charging port.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
IUPUI, Team S2-G1, Freund Spring 2018 IUPUI, Team S2-G1, Freund Spring 2018 的会员
IUPUI-FREUND-S18S2G1
2 名成员
创作了14篇指南
4指南评论
Great Job, Thank you!
Bob Olive Sr - 回复 分享
Great thanks where did you get the replacement cable please thanks Mike
mikewalters1951 - 回复 分享
where did you get the replacement cable please thanks  BOB
robertwatkins61 - 回复 分享
Any hints on where the new port came from? I have the baby monitor and the port is cheap rubbish and needs replacing. Thanks
David - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 47
总计 6,035
