跳转到主内容
Nest Thermostat E Dial Replacement
你所需要的
  1. Nest Thermostat E Dial Replacement, Base Plate: 步骤 1 中的图像 1,1
    • Grasp the display's outer ring with your fingers and pull directly away while rotating clockwise to remove the thermostat from the wall.
    • Go to the electrical panel and turn off the circuit to make sure no power is running to the thermostat.
    • Once the power is off, disconnect the Y1, G, R, W1, C, and OB wires.
    • Remember the placement of each wire for reassembly.
  2. Nest Thermostat E Dial Replacement: 步骤 2 中的图像 1,1
    • Remove the two 1 ¼” drywall screws holding the base display and base plate in the wall using a Phillips #2 screwdriver.
    • Remove the base plate and base display.
  3. Nest Thermostat E Dial Replacement: 步骤 3 中的图像 1,1
    • Pry the base display off of the baseplate using an iFixit opening tool.
  4. Nest Thermostat E Dial Replacement, Dial: 步骤 4 中的图像 1,1
    • Remove the four 6 mm screws using a Phillips #0 screwdriver.
    • The two smaller screws go around the pin connector and the two larger screws go by the outside bezel.
    • Grab the pin connector and pull up to remove the thermostat backplate from the thermostat.
  5. Nest Thermostat E Dial Replacement: 步骤 5 中的图像 1,1
    • Remove the four screws.
  6. Nest Thermostat E Dial Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Grasp the orange tab with tweezers and gently pull the ribbon cable directly away from the motherboard.
  7. Nest Thermostat E Dial Replacement: 步骤 7 中的图像 1,1
    • Flip the display over and the battery casing will fall from the base.
  8. Nest Thermostat E Dial Replacement: 步骤 8 中的图像 1,1
    • Remove the six screws.
  9. Nest Thermostat E Dial Replacement: 步骤 9 中的图像 1,2 Nest Thermostat E Dial Replacement: 步骤 9 中的图像 2,2
    • Push out the display from the dial.
    • You might have to twist slightly.
    • Do not apply too much force which might cause the Nest Thermostat E screen to break.
    • You might hear a pop which signifies that the display came out of the display holder.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 21
总计 221
