跳转到主内容
Nest Protect Backplate Replacement
你所需要的
    • Remove the Protect from it’s backplate by twisting counterclockwise on the device until it releases.
    • Unscrew the backplate.
    • Battery operated: Fully remove the backplate screws.
    • Hardwired: Slightly remove the backplate screws and twist the backplate.
    • Pull the backplate off the wall.
    • Place the backplate on the wall.
    • Battery Operated: Screw in the backplate.
    • Hardwired: Twist the backplate so it locks into place and snug the screws
    • 1ST Generation: Twist clockwise until it clicks into place
    • 2ND Generation: Twist clockwise until it grips and adjust to fit the wall or ceiling of wall mounted.
结论
Logan
于04/24/19注册
121 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 25
总计 2,277
