跳转到主内容
Nest Learning Thermostat 2nd Generation LCD Screen Replacement
你所需要的
  1. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Removal from Wall: 步骤 1 中的图像 1,2 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Removal from Wall: 步骤 1 中的图像 2,2
    • Grasp the display's metal outer ring with your fingers and pull directly away from the wall.
  2. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Open Display: 步骤 2 中的图像 1,1
    • Turn the display over.
    • Remove the four 6 mm screws from the back of the display using a Phillips #0 screwdriver.
  3. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove the back of the display: 步骤 3 中的图像 1,2 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove the back of the display: 步骤 3 中的图像 2,2
    • Pinch the gray 20-pin connector with your fingers and pull directly away from the display.
    • Do NOT pull too far as there is a ribbon on the back panel connecting the 20-pin connector to the display.
  4. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect the base connection ribbon cable.: 步骤 4 中的图像 1,3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect the base connection ribbon cable.: 步骤 4 中的图像 2,3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect the base connection ribbon cable.: 步骤 4 中的图像 3,3
    • Locate the blue pull tab at the end of the ribbon which says, "1. Pull".
    • Grasp the tab with your fingers and pull directly away from the motherboard.
  5. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Lift battery from the base: 步骤 5 中的图像 1,2 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Lift battery from the base: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • Locate the blue tab which says, "2. Pull".
    • Use tweezers to pull the battery up and away from the display.
    • Do NOT pull too far, as the battery is still connected to the motherboard and must be unplugged.
  6. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect the battery from the motherboard: 步骤 6 中的图像 1,2 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect the battery from the motherboard: 步骤 6 中的图像 2,2
    • Locate the blue tab which says "3 unplug".
    • Grasp the battery with your fingers. Pull gently directly away from the display to unplug the battery from the motherboard.
  7. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove battery from the display: 步骤 7 中的图像 1,3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove battery from the display: 步骤 7 中的图像 2,3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove battery from the display: 步骤 7 中的图像 3,3
    • Grasp the battery with your fingers and pull directly away from motherboard to separate the battery from the display.
  8. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Locate auto-away sensor: 步骤 8 中的图像 1,1
    • Locate the auto-away sensor.
  9. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove screws: 步骤 9 中的图像 1,2 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove screws: 步骤 9 中的图像 2,2
    • Remove the four 3mm screws with a #0 Phillips screwdriver.
    • Remove the one 4mm screw located at the edge of the auto-away sensor. Use a #0 Phillips screwdriver.
  10. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove auto-away sensor: 步骤 10 中的图像 1,3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove auto-away sensor: 步骤 10 中的图像 2,3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove auto-away sensor: 步骤 10 中的图像 3,3
    在这个步骤中使用的工具:
    • Lift the auto-away sensor from motherboard using tweezers.
    • Peel the copper foil gently from the EMI shield.
  11. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove screw from motherboard: 步骤 11 中的图像 1,1
    • Remove one 4 mm screw from the motherboard using a #0 Phillips screwdriver.
  12. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove EMI shield from motherboard: 步骤 12 中的图像 1,2 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove EMI shield from motherboard: 步骤 12 中的图像 2,2
    • Remove the EMI shield from the motherboard using the plastic opening tools.
  13. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect the LCD ribbon from the motherboard: 步骤 13 中的图像 1,2 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect the LCD ribbon from the motherboard: 步骤 13 中的图像 2,2
    在这个步骤中使用的工具:
    • Unsnap the LCD ribbon from the motherboard gently using the tweezers.
  14. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect display from motherboard: 步骤 14 中的图像 1,3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect display from motherboard: 步骤 14 中的图像 2,3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect display from motherboard: 步骤 14 中的图像 3,3
    • Locate the black tabs that hold the display to the motherboard.
    • Push the black tabs gently away from the motherboard using the plastic opening tools.
  15. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove from motherboard: 步骤 15 中的图像 1,2 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove from motherboard: 步骤 15 中的图像 2,2
    • Pull the face display gently away from the motherboard.
  16. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove bottom of display frame: 步骤 16 中的图像 1,3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove bottom of display frame: 步骤 16 中的图像 2,3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove bottom of display frame: 步骤 16 中的图像 3,3
    • The front of the glass display and plastic frame is held together by only light adhesive.
    • Push the crescent shape bottom of the display away from the plastic frame using the plastic opening tools.
  17. Nest Learning Thermostat 2nd Generation LCD Screen Replacement: 步骤 17 中的图像 1,1
    • Pry the front glass and plastic frame apart gently using the plastic opening tools.
  18. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove LCD screen from plastic frame: 步骤 18 中的图像 1,2 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove LCD screen from plastic frame: 步骤 18 中的图像 2,2
    • Pry the LCD screen gently from the plastic frame using the plastic opening tools.
  19. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Separate LCD from frame: 步骤 19 中的图像 1,3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Separate LCD from frame: 步骤 19 中的图像 2,3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Separate LCD from frame: 步骤 19 中的图像 3,3
    • Pull the LCD screen away from the plastic frame gently using your fingers.
结论
8等其他人完成本指南。
Justin Curry
于09/23/14注册
264 声望
创作了2篇指南
团队
USF Tampa, Team 11-5, Blackwell Fall 2014 USF Tampa, Team 11-5, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S11G5
5 名成员
创作了12篇指南
5指南评论
Please could you say the type of LCD screen? Or present detailed photo of rear side?
vladvys - 回复
Yes, this is a guide for replacing the LCD. I'd like to know what LCD to order. Thanks.
kylegoetz - 回复
Thank you for providing this tutorial. My dog, not making this up, knocked my nest off the wall. Where can I purchase the replacement green itself and the plastic opening tools you used throughout the repair? This will be my first time on something like this, but with your guide I should have a decent shot at not screwing it up.
erick.starke - 回复
Skip step 12. There is no reason to remove the EMI shield.
richardrobison - 回复
Where can you get the replacement lcd screen for gen 2 nest learning thermostat?
Stan Griff - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 121
总计 16,198
