跳转到主内容
Nest Learning Thermostat 2nd Generation Base Motherboard Replacement
你所需要的
  1. Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove display from wall: 步骤 1 中的图像 1,3 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove display from wall: 步骤 1 中的图像 2,3 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove display from wall: 步骤 1 中的图像 3,3
    • Before disassembling your Nest Thermostat, be sure that your HVAC system is powered off.
    • Grasp the display's metal outer ring with your fingers and pull directly away from the wall, leaving the base behind.
  2. Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Disconnect wires: 步骤 2 中的图像 1,3 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Disconnect wires: 步骤 2 中的图像 2,3 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Disconnect wires: 步骤 2 中的图像 3,3
    • Remember to turn off the power to your HVAC system and the thermostat.
    • Disconnect all wires from the grey spring-loaded connectors. This can be done using your fingers.
    HOW do you disconnect the wires? I can't get them out!
    Beverley Brown - 回复
    Same here. It is like the springs are in a stuck position
    Bill Redfield - 回复
    I also can not dis-engage the wires. Feels like the springs are frozen closed.
    Bill Redfield - 回复
    Hold down the button on the end and the wire should be able to slide right out.
    Amber - 回复
    Yes, the button on the end of the wires is stuck in the down position. Tried pushing with my fingers and several smaller tools- they appear to be frozen in the down position.
    Garet Ten Cate - 回复
    If you hold the buttons down while pulling the wires, they'll come right out and the button springs reset.
    Dan - 回复
  3. Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove screws from wall: 步骤 3 中的图像 1,1
    • Remove the two 40mm screws from the base of the thermostat using a #0 Phillips screw driver.
  4. Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove base from trim plate: 步骤 4 中的图像 1,3 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove base from trim plate: 步骤 4 中的图像 2,3 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove base from trim plate: 步骤 4 中的图像 3,3
    • Unsnap the base from the trim plate (if used) using a plastic opening tool.
  5. Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove screws from back of base: 步骤 5 中的图像 1,2 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove screws from back of base: 步骤 5 中的图像 2,2
    • Turn the base over.
    • Remove the four 6 mm screws from the back of the base using a #0 Phillips screwdriver.
  6. Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Opening base: 步骤 6 中的图像 1,2 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Opening base: 步骤 6 中的图像 2,2
    • Pry the base mother board open from the side using a plastic opening tool.
  7. Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove base motherboard from base back: 步骤 7 中的图像 1,3 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove base motherboard from base back: 步骤 7 中的图像 2,3 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove base motherboard from base back: 步骤 7 中的图像 3,3
    • The base mother board is only held together by light adhesive.
    • Pry the baseboard from the bottom using the flat end of a spudger.
结论
6等其他人完成本指南。
Rachael Deptula
于09/03/14注册
1,102 声望
撰写一个指南
团队
USF Tampa, Team 11-5, Blackwell Fall 2014 USF Tampa, Team 11-5, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S11G5
5 名成员
创作了12篇指南
8条评论
Would like to know where I can get just the base motherboard.
wesbug - 回复
Where can we purchase replacement parts?
brettspradley - 回复
i want the baseboard.. where i can buy? pls help...
john gemora - 回复
Yep, my base unit lasted exactly 8 days, then it shorted out. The furnace repairman said he has seen it a couple of times, the base unit can't handle the current needed by the furnace so it goes poof. Back to Honeywell...
bbolen - 回复
No replacement parts from Nest, my base unit died and I have perfectly working thermostat but am forced to buy a new one cause I can't get the base unit on its own.
Adrian Ma - 回复
I have no clue why people like their thermostats to the degree that they do.. I am both an A/c professional and an Engineer. They use what is called an SCR or silicon controlled rectifier for their switching instead of a tiny relay. An SCR is very sensitive to a spark or voltage spike. Yes the thermostat is pretty cool and has some nice features. It is advanced electronics but using SMC's or Surface Mounted Components?? . Maybe that would work well in a shielded component. But NOT in something that is connected to long external wires. The consumer bought warranty is only one year. I have seen too many issues in the field with their overpriced toys. Not having parts for this Chinese made thermostat? Priceless.
Jon Reid - 回复
Hey Jon, I’m trying to repair my parent’s 2nd Gen Nest. It sends out “heat” and “cool” signal at the same time. Anyway I can replace a component on the motherboard?
Lizik -
Good post. Wish I had read before I got a Nest thermostat. What would you recommend as a good alternative? I hate when you can't replace simple components and parts cheaply and quickly. What the !&&*.
doughboy1338 -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 71
总计 92,939
