跳转到主内容
Nest Learning Thermostat 2nd Generation Base Motherboard Replacement
你所需要的
  1. Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove display from wall: 步骤 1 中的图像 1,3 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove display from wall: 步骤 1 中的图像 2,3 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove display from wall: 步骤 1 中的图像 3,3
    • Before disassembling your Nest Thermostat, be sure that your HVAC system is powered off.
    • Grasp the display's metal outer ring with your fingers and pull directly away from the wall, leaving the base behind.
  2. Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Disconnect wires: 步骤 2 中的图像 1,3 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Disconnect wires: 步骤 2 中的图像 2,3 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Disconnect wires: 步骤 2 中的图像 3,3
    • Remember to turn off the power to your HVAC system and the thermostat.
    • Disconnect all wires from the grey spring-loaded connectors. This can be done using your fingers.
  3. Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove screws from wall: 步骤 3 中的图像 1,1
    • Remove the two 40mm screws from the base of the thermostat using a #0 Phillips screw driver.
  4. Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove base from trim plate: 步骤 4 中的图像 1,3 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove base from trim plate: 步骤 4 中的图像 2,3 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove base from trim plate: 步骤 4 中的图像 3,3
    • Unsnap the base from the trim plate (if used) using a plastic opening tool.
  5. Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove screws from back of base: 步骤 5 中的图像 1,2 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove screws from back of base: 步骤 5 中的图像 2,2
    • Turn the base over.
    • Remove the four 6 mm screws from the back of the base using a #0 Phillips screwdriver.
  6. Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Opening base: 步骤 6 中的图像 1,2 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Opening base: 步骤 6 中的图像 2,2
    • Pry the base mother board open from the side using a plastic opening tool.
  7. Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove base motherboard from base back: 步骤 7 中的图像 1,3 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove base motherboard from base back: 步骤 7 中的图像 2,3 Nest Learning Thermostat 2nd Generation Base Motherboard Replacement, Remove base motherboard from base back: 步骤 7 中的图像 3,3
    • The base mother board is only held together by light adhesive.
    • Pry the baseboard from the bottom using the flat end of a spudger.
结论
6等其他人完成本指南。
Rachael Deptula
于09/03/14注册
1,126 声望
撰写一个指南
团队
USF Tampa, Team 11-5, Blackwell Fall 2014 USF Tampa, Team 11-5, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S11G5
5 名成员
创作了12篇指南
8指南评论
Would like to know where I can get just the base motherboard.
wesbug - 回复
Where can we purchase replacement parts?
brettspradley - 回复
i want the baseboard.. where i can buy? pls help...
john gemora - 回复
Yep, my base unit lasted exactly 8 days, then it shorted out. The furnace repairman said he has seen it a couple of times, the base unit can't handle the current needed by the furnace so it goes poof. Back to Honeywell...
bbolen - 回复
No replacement parts from Nest, my base unit died and I have perfectly working thermostat but am forced to buy a new one cause I can't get the base unit on its own.
Adrian Ma - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 94
总计 93,919
