跳转到主内容
加入维修社区 - 创建账户
Nest Hello O-Ring Replacement
你所需要的
  1. Nest Hello O-Ring Replacement, Casing and Faceplate: 步骤 1 中的图像 1,1
    • Insert the pick between the black faceplate and white casing of the Nest Hello.
    • Pry the faceplate away from the device with the opening pick.
    • If you have not opened the Nest Hello before, there will be a protective foam mesh that is glued to the plastic covering and the inside of the mesh, use a pick to cut through the mesh as much as possible.
    • Completely remove the faceplate from the device, do not be afraid to pull hard.
  2. Nest Hello O-Ring Replacement: 步骤 2 中的图像 1,2 Nest Hello O-Ring Replacement: 步骤 2 中的图像 2,2
    • Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
  3. Nest Hello O-Ring Replacement: 步骤 3 中的图像 1,3 Nest Hello O-Ring Replacement: 步骤 3 中的图像 2,3 Nest Hello O-Ring Replacement: 步骤 3 中的图像 3,3
    • Insert opening pick between the white casing and the black internal circuitry and pry it out.
    • There is a ribbon cable connecting the white casing to the circuit boards. Be careful not to tear out the cable while separating the casing from the circuit boards.
  4. Nest Hello O-Ring Replacement, O-Ring: 步骤 4 中的图像 1,1
    • Remove the O-Ring (colored blue) from the device. It is placed around the edge of the motherboard.
结论
3等其他人完成本指南。
2指南评论
Is there a link available for spare replacement parts? I can’t seem to find anything other than replacement internal batteries . Thanks!
Andres Chavez - 回复
Also looking for this replacement part. Googling did not produce results.
KB_KB - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 25
过去 30 天: 140
总计 4,755
