跳转到主内容
加入维修社区 - 创建账户
Nest Hello Microphone Replacement
你所需要的
    1. Nest Hello Microphone Replacement, Casing and Faceplate: 步骤 1 中的图像 1,1
      • Insert the pick between the black faceplate and white casing of the Nest Hello.
      • Pry the faceplate away from the device with the opening pick.
      • If you have not opened the Nest Hello before, there will be a protective foam mesh that is glued to the plastic covering and the inside of the mesh, use a pick to cut through the mesh as much as possible.
      • Completely remove the faceplate from the device, do not be afraid to pull hard.
      添加评论
    2. Nest Hello Microphone Replacement: 步骤 2 中的图像 1,2 Nest Hello Microphone Replacement: 步骤 2 中的图像 2,2
      • Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
      添加评论
    3. Nest Hello Microphone Replacement: 步骤 3 中的图像 1,3 Nest Hello Microphone Replacement: 步骤 3 中的图像 2,3 Nest Hello Microphone Replacement: 步骤 3 中的图像 3,3
      • Insert opening pick between the white casing and the black internal circuitry and pry it out.
      • There is a ribbon cable connecting the white casing to the circuit boards. Be careful not to tear out the cable while separating the casing from the circuit boards.
      添加评论
    1. Nest Hello Microphone Replacement, Motherboard: 步骤 4 中的图像 1,1
      • Use the Phillips #000 to remove the two screws holding the ribbon cable to the white casing.
      询问修复机器人
      添加评论
    2. Nest Hello Microphone Replacement: 步骤 5 中的图像 1,2 Nest Hello Microphone Replacement: 步骤 5 中的图像 2,2
      在这个步骤中使用的工具:
      • Grip the connector with the tweezers as shown and pull it away from the casing.
      询问修复机器人
      添加评论
    3. Nest Hello Microphone Replacement: 步骤 6 中的图像 1,1
      • Remove the six smaller screws shown with the Phillips #000 screwdriver.
      • Remove the three larger screws shown with the Phillips #000 screwdriver.
      添加评论
    4. Nest Hello Microphone Replacement: 步骤 7 中的图像 1,2 Nest Hello Microphone Replacement: 步骤 7 中的图像 2,2
      • Holding the device as shown push the circuit board away from you and up to free it from the clips.
      询问修复机器人
      添加评论
    5. Nest Hello Microphone Replacement: 步骤 8 中的图像 1,2 Nest Hello Microphone Replacement: 步骤 8 中的图像 2,2
      • Use the Phillips #000 screwdriver to remove the three screws holding the last circuit board to the black plastic housing.
      询问修复机器人
      添加评论
    6. Nest Hello Microphone Replacement: 步骤 9 中的图像 1,1
      • Insert the pick underneath the black connectors and pry them upward to disconnect them from the circuit board.
      • Work your way around the device, prying the circuit board away from the housing.
      • Make sure to feed the wires when taking off the circuit board.
      询问修复机器人
      添加评论
      • The microphone on this device is integrated into the black plastic housing removed in the previous step. This entire piece must be replaced rather than the microphone individually.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
1指南评论
Where did you get the microphone replacement part?
Pedro Cruz - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 37
总计 1,899
