跳转到主内容
加入维修社区 - 创建账户
Nest Hello Camera Replacement
浏览量: 3000
浏览统计数据:
过去24小时
3
过去 7 天:
18
过去 30 天:
84
总计
3,000
评论: 18
18 comments on steps.
已完成: 1
1 人已将本指南标记为“已完成”。你会是下一个完成的人吗?
收藏: 0
暂时还没有人收藏(和订阅)本指南。你会是第一个收藏(和订阅)的人吗?
所需时间: 20 - 30 分钟
难度: 中等
需要更好的图片
更好的照片将改善本指南。请帮助拍摄,编辑,或上传新的图片​​!
If you are not receiving video, or the picture is blurred or discolored, then a faulty camera may be the issue. If troubleshooting has led you here, then this guide will help you change the camera in your Nest Hello. Disassembly will require the iFixit opening picks, Phillips #000 screwdriver, and tweezers. It is easy to damage the waterproofing O-Ring while removing the faceplate and device housing, so [|plan on replacing that as well.]
你所需要的
工具
    1. Nest Hello Camera Replacement, Casing and Faceplate: 步骤 1 中的图像 1,1
      • Insert the pick between the black faceplate and white casing of the Nest Hello.
      • Pry the faceplate away from the device with the opening pick.
      • If you have not opened the Nest Hello before, there will be a protective foam mesh that is glued to the plastic covering and the inside of the mesh, use a pick to cut through the mesh as much as possible.
      • Completely remove the faceplate from the device, do not be afraid to pull hard.
      添加评论
    2. Nest Hello Camera Replacement: 步骤 2 中的图像 1,2 Nest Hello Camera Replacement: 步骤 2 中的图像 2,2
      • Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
      添加评论
    3. Nest Hello Camera Replacement: 步骤 3 中的图像 1,3 Nest Hello Camera Replacement: 步骤 3 中的图像 2,3 Nest Hello Camera Replacement: 步骤 3 中的图像 3,3
      • Insert opening pick between the white casing and the black internal circuitry and pry it out.
      • There is a ribbon cable connecting the white casing to the circuit boards. Be careful not to tear out the cable while separating the casing from the circuit boards.
      添加评论
    1. Nest Hello Camera Replacement, Motherboard: 步骤 4 中的图像 1,1
      • Use the Phillips #000 to remove the two screws holding the ribbon cable to the white casing.
      询问修复机器人
      添加评论
    2. Nest Hello Camera Replacement: 步骤 5 中的图像 1,2 Nest Hello Camera Replacement: 步骤 5 中的图像 2,2
      在这个步骤中使用的工具:
      • Grip the connector with the tweezers as shown and pull it away from the casing.
      询问修复机器人
      添加评论
    3. Nest Hello Camera Replacement: 步骤 6 中的图像 1,1
      • Remove the six smaller screws shown with the Phillips #000 screwdriver.
      • Remove the three larger screws shown with the Phillips #000 screwdriver.
      添加评论
    4. Nest Hello Camera Replacement: 步骤 7 中的图像 1,2 Nest Hello Camera Replacement: 步骤 7 中的图像 2,2
      • Holding the device as shown push the circuit board away from you and up to free it from the clips.
      询问修复机器人
      添加评论
    5. Nest Hello Camera Replacement: 步骤 8 中的图像 1,2 Nest Hello Camera Replacement: 步骤 8 中的图像 2,2
      • Use the Phillips #000 screwdriver to remove the three screws holding the last circuit board to the black plastic housing.
      询问修复机器人
      添加评论
    6. Nest Hello Camera Replacement: 步骤 9 中的图像 1,1
      • Insert the pick underneath the black connectors and pry them upward to disconnect them from the circuit board.
      • Work your way around the device, prying the circuit board away from the housing.
      • Make sure to feed the wires when taking off the circuit board.
      询问修复机器人
      添加评论
    1. Nest Hello Camera Replacement, Camera: 步骤 10 中的图像 1,3 Nest Hello Camera Replacement, Camera: 步骤 10 中的图像 2,3 Nest Hello Camera Replacement, Camera: 步骤 10 中的图像 3,3
      • Remove the plug connecting the camera to the device.
      询问修复机器人
      添加评论
    2. Nest Hello Camera Replacement: 步骤 11 中的图像 1,3 Nest Hello Camera Replacement: 步骤 11 中的图像 2,3 Nest Hello Camera Replacement: 步骤 11 中的图像 3,3
      • Lift the top layer of circuits to reveal the unplugged camera.
      • Lift up the camera and remove it from the device.
      • If you flip the camera upside down a black rubber rectangle will fall out.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 84
总计 3,000
