简介
If the doorbell button on your Nest Hello is cracked or leaking, this guide will help you access and replace it. During disassembly, it is easy to damage the waterproofing O-Ring, so plan on replacing that as well. This does involve removing all of the internals from the device using the iFixit opening picks, Phillips #000 screwdriver, and tweezers. Be sure to take your time and keep track of screws and other parts.
你所需要的
Insert the pick between the black faceplate and white casing of the Nest Hello.
Pry the faceplate away from the device with the opening pick.
Completely remove the faceplate from the device, do not be afraid to pull hard.
Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
Insert opening pick between the white casing and the black internal circuitry and pry it out.
I ended up doing the headlight lens restoration method - I scraped away any plastic that was flaking off and then I used progressively finer sandpaper (start with 400-600 grit and go up from there). I finished it with rubbing compound and polish. Looks decent.
Also - be careful not to cut or displace the rubber gasket that runs around the outside of the main body that has the circuitry - you'll risk losing the waterproofing
What is the replacement battery type please?
The top end has some kind of mild adhesive (the blue stuff). The bottom end came out more easily for me, and then I ended up bending my board slightly by trying to pry out the top end. May be better to start on the top end if you can get something under the edge of the board to get leverage.
The black ribbon cable was instantly sheared in half the moment I got the two halves apart, which took more force than I was hoping to need. Turns out the ribbon cable is attached to a sharp metal piece and it will easily tear through it. No longer worth it to replace the battery for me, sadly.
What a stupid design by Nest. If they know that battery will fail they should at least make it user accessible when removed from mount. Replaced mine. It’s a pain getting to the battery and it’s easy to crack the faceplate when prying it off. Also the plastic tools included with kit will fail before you’re into the device.
If you can manage to get to the battery without destroying the Nest Doorbell it’s worth it to get a few more years of use.
C Whitcher - 回复
Use the Phillips #000 to remove the two screws holding the ribbon cable to the white casing.
Remove the six smaller screws shown with the Phillips #000 screwdriver.
Remove the three larger screws shown with the Phillips #000 screwdriver.
Once the circuitboard is free from the plastic housing, the button can be removed by pushing on it from the front side.
2条评论
Where do you get the parts. Google is no help. I’m trying to get the black faceplate from your first step. I can’t find it.
Where do I buy a button?
Joel Lundi - 回复
I had to use a metal spudger tool to start and then used guitar picks.
Joel Lundi - 回复
Be afraid to pull hard. The faceplate will break in two.
B Bremer - 回复
I did the JerryRigEverything method and slipped a razor under the faceplate to separate it carefully from the body. Worked perfectly and nothing was damaged
There I Fixed It - 回复
Be careful with the wiring and the heater element. I must have shorted something together when it put it back together and now it will no longer power up. It is probably best to cut the wires to the heater and deal with the consequences in the cold temperatures.
Joe I. Fabritz - 回复
